Re: 383 with MP .474 cam - anyone running this combo? [Re: ZIPPY] #189503
01/11/09 06:33 PM
01/11/09 06:33 PM
napa lists the shim online. Doesn't mean they have them but they are listed.
Re: 383 with MP .474 cam - anyone running this combo? #189504
01/11/09 06:52 PM
01/11/09 06:52 PM
Utah
topbrent Offline
topbrent  Offline
Utah
We had one in a low comp 383. Our 75 dodge truck is probably the same weight as your newport
Performer RPM, good exhaust, good ignition. Bowl Ported 906 heads.
Doggiest engine ever. Gas pig. No torque.
We learned some good lessons because of that cam though, such as:
- Have a modern lobe profile cam ground up, or use one an off the shelf comp XE. Small hughes, Bullet/ultradyne/,voodoo, whatever...
- Low comp 383's aren't for heavy vehicles.
If it were me...I'd pass on the MP
Re: 383 with MP .474 cam - anyone running this combo? [Re: topbrent] #189505
01/11/09 07:27 PM
01/11/09 07:27 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I ran one in my 70 Challenger. Stock 383HP convertor, stock intake and exhaust system, true 9.5 compression, cam degreed in. I didn't like it, not much performance IMO, I think it would have run better with the stock cam.
Sheldon
Re: 383 with MP .474 cam - anyone running this combo? [Re: TonyS451] #189506
01/11/09 09:10 PM
01/11/09 09:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thanks for the input and posting your combos. The engine is a '67 383. Not sure of the compression, but I can only imagine with the open chambered heads its not good. I also have no idea if/when the engine has been rebuilt, so I can only assume they are stock slugs. It "looks" like it has been worked on, or at least painted on not too long ago.
I can always mill the heads for some compression, but thats about as much as I care to invest into this engine. On a side note, what happened to the MP steel shim head gaskets? Can't seem to find them anywhere, but then I found Summit has them listed for almost $200 dollars. Didn't they used to cost like $20 bucks?
I'll sell you mine for half that!(not $20)
Re: 383 with MP .474 cam - anyone running this combo? [Re: ZIPPY] #189507
01/11/09 11:57 PM
01/11/09 11:57 PM
Bellevue, WA
Blackwidow69 Offline
Ring Knocker
Ring Knocker
Bellevue, WA
I think if it is a budget deal and you do not already own the 474 then you should look at the summit cams. I think the larger of the 2 summit cams is still smaller than the 474 and will work better in your setup.
Todd
1969 Ply Roadrunner, 383 4-speed on street tires. 3,830 lbs race weight. Best 1/4: 13.1 @ 106.83 440 & overdrive 4 speed going in. 2005 Power Wagon 35X12.5 KM2's
