2004 Dakota Brake Line Replacement Question #1894528
08/18/15 04:41 PM
08/18/15 04:41 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
My Dakota blew the steel brake line that runs from the front to the back recently. New one arrives tomorrow.
Do I need to drop the fuel tank to change out this line?
Thanks!
Erik
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 2004 Dakota Brake Line Replacement Question [Re: Erik] #1894846
08/18/15 10:15 PM
08/18/15 10:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Probably not but it would make it easier. Why did you get a prebent line?
Angry white pureblood male
Re: 2004 Dakota Brake Line Replacement Question [Re: Erik] #1894847
08/18/15 10:15 PM
08/18/15 10:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Re: 2004 Dakota Brake Line Replacement Question [Re: ruderunner] #1894978
08/18/15 11:59 PM
08/18/15 11:59 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
I just did my 2000 dakota. unless you have a hoist or don't care how it is ran you can leave the tank in. I bought the pre bent from the dealer and wanted it in place, I had to remove the gas tank to get to all the clips and bolts for the brackets. I ended up replacing all the steel lines. just made the rest though. you will need a bubble flare tool and multiple size METRIC fitting. and time. between chasing down the fittings and laying on my back and dealing with rust, It took a weekend. I have done hundred of lines in a shop. wasn't my first rodeo. not fun on your back.
Re: 2004 Dakota Brake Line Replacement Question [Re: Erik] #1895161
08/19/15 08:38 AM
08/19/15 08:38 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I ordered the pre-bent line. And I will be on the ground doing this one. LOL
