'83 Ram D150 K member? #1894068
08/18/15 12:19 AM
08/18/15 12:19 AM
Nebraska
demononwheels Offline OP
Nebraska
Hi, I bought a Ram D150 about a month ago. I have the bed, cab and engine out. In the process of clean up the frame. I would like to remove the K-member so I can clean up between it and the inside of the frame. My question is, Is it safe to replaced the rivets with bolts, or should I just leave it and try to clean and paint the best I can? Thanks.
1974 Dart Sport 383 4spd
1983 Ram D150 Short Bed 4spd
2013 Dart Rallye
Re: '83 Ram D150 K member? [Re: demononwheels] #1894082
08/18/15 12:38 AM
08/18/15 12:38 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Leave it and clean and paint as best you can. You should be clean what you want without removing it.
Re: '83 Ram D150 K member? [Re: demononwheels] #1894168
08/18/15 03:23 AM
08/18/15 03:23 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
It's harder to remove than it looks
Re: '83 Ram D150 K member? [Re: demononwheels] #1894269
08/18/15 11:38 AM
08/18/15 11:38 AM
Nebraska
Nebraska
Thanks, I think I will leave it.
2013 Dart Rallye
Re: '83 Ram D150 K member? [Re: demononwheels] #1894297
08/18/15 12:32 PM
08/18/15 12:32 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Besides the clamping force hot rivets form a perfect tight fitment between the rivet shank and the holes in the material being fastened together to prevent shearing movement. A regular nut and bolt wont do the same unless the holes were reamed and fitted with close tolerance bolts that would almost be a press fit through the material to do the same thing. Huck bolts would be ideal to replace the rivets but most people don't have a huck gun in their tool box.
Re: '83 Ram D150 K member? [Re: 135sohc] #1894566
08/18/15 05:29 PM
08/18/15 05:29 PM
Nebraska
Nebraska
That's what I thought. One thing though. I don't know if it was a mistake when it was first riveted. One of the rivets, on the passenger forward rivet for the k-member, it looks like they missed the hole with the rivet on the outboard side of the frame you can see indents, on the inboard the top of the k-member is cut off, and there is a bolts in its place. ill have to get a picture of it.
2013 Dart Rallye
Re: '83 Ram D150 K member? [Re: demononwheels] #1894624
08/18/15 06:31 PM
08/18/15 06:31 PM
Nebraska
Nebraska
2013 Dart Rallye
Re: '83 Ram D150 K member? [Re: demononwheels] #1894698
08/18/15 07:49 PM
08/18/15 07:49 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
At least it is a grade 8 bolt. I would not worry about it at all. Of more concern is where the steering box bolts to the left frame rail...look for cracks there.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
