Finally Got It Fired.... AGAIN
#1894589
08/18/15 05:54 PM
08/18/15 05:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I got it fired up and checked the trans... everything seems to function fine... I had a few issues that I screwed up on... I couldnt get fuel pressure on the gauge... I messed up and put the lines on backwards at the fender... changed that after loosening the fitting and spraying fuel...still need to set the timing and hook up the steering at the rack(I have to pull that to get the headers in and out).... but it works/runs and the tires turn in all gears and OD... now to give it a bath and a quick check over
Re: Finally Got It Fired.... AGAIN
[Re: WO23Coronet]
#1894602
08/18/15 06:05 PM
08/18/15 06:05 PM
MR_P_BODY
Was the tranny locking up on you in OD? It was last time... mess up on assembly... had too many clutch disc in it and it couldnt release one set when the other was suppose to come on... it just didnt have any clearance to release... got it all figured out... finally... it goes into OD nicely now... I want to get it out on the street to check the governor shift points... I'm hoping they are fairly low.. like shift to 2nd at 15 to 18 mph
[Re: MR_P_BODY]
#1894607
08/18/15 06:10 PM
08/18/15 06:10 PM
Posts: 7,506 Az
Crizila
Az
Fastest 300
[Re: Crizila]
#1894614
08/18/15 06:21 PM
08/18/15 06:21 PM
MR_P_BODY
I want to make the Hines Drive cruise.. that will be a good test run for it... thats this Saturday... that will be about 125 miles round trip
[Re: MR_P_BODY]
#1894622
08/18/15 06:29 PM
08/18/15 06:29 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I want to make the Hines Drive cruise.. that will be a good test run for it... thats this Saturday... that will be about 125 miles round trip Are you sure you remember how to drive one of these hotrods lol J/K glad to see you made progress and getting out there.
[Re: Sammy]
#1894634
08/18/15 06:40 PM
08/18/15 06:40 PM
MR_P_BODY
I want to make the Hines Drive cruise.. that will be a good test run for it... thats this Saturday... that will be about 125 miles round trip Are you sure you remember how to drive one of these hotrods lol J/K glad to see you made progress and getting out there. I hope I remember... if everything goes smoothly then yes I should remember.. if not.. there might be a fire on the side of the road
[Re: MR_P_BODY]
#1894701
08/18/15 07:50 PM
08/18/15 07:50 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I hope I remember... if everything goes smoothly then yes I should remember.. if not.. there might be a fire on the side of the road lol...
[Re: MR_P_BODY]
#1894715
08/18/15 08:04 PM
08/18/15 08:04 PM
Posts: 20,180 Park Forest, IL
slantzilla
Park Forest, IL
Congratulations Mike! Hope it all goes well.
[Re: barracuda man]
#1894748
08/18/15 08:42 PM
08/18/15 08:42 PM
MR_P_BODY
glad your doing well mike.u have any pic of the ride?Mines still in the trailer with a broke rod.Just to hot to work on it now maybe oct i'ii get it out and have a look. Believe me.. its been hot here.... but I didnt have any choice if I want to make drag week.. I have less than a month to get things sorted out.. and it hasnt been on the track yet... the humidity here has been up there. along with close to 90*
[Re: MR_P_BODY]
#1894790
08/18/15 09:26 PM
08/18/15 09:26 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Glad to know its running again. I hope to light off the new power plant this weekend. See you in St Louis
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#1894869
08/18/15 10:34 PM
08/18/15 10:34 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The car looks very nice. Good job.
[Re: TRENDZ]
#1894887
08/18/15 10:46 PM
08/18/15 10:46 PM
MR_P_BODY
This was what the front end looked like a month ago... damn hard to find parts for a 2 door L-body or Rampage this was a cherry picker failure(the cyl ram gave out and bent and set the engine on the front end) EDIT this pic is after lifting the engine off the front end... it was pretty much flat on the floor
[Re: MR_P_BODY]
#1894943
08/18/15 11:20 PM
08/18/15 11:20 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Glad to hear she's back together, Mike! There's no quit in you, that's for sure!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: J_BODY]
#1894997
08/19/15 12:24 AM
08/19/15 12:24 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
your choices of turds to polish never ceases to amaze me.... but THAT is one COOL looking Rampage P! Hope that baby runs smooth and true! Working in that humidity is HE77! I'll take my 120+ fairly dry climate any day. Yes, much better to be BBQ'd than boiled. Glad you're making progress Mike. Kevin
[Re: J_BODY]
#1895055
08/19/15 01:22 AM
08/19/15 01:22 AM
MR_P_BODY
your choices of turds to polish never ceases to amaze me.... but THAT is one COOL looking Rampage P! Hope that baby runs smooth and true! Working in that humidity is HE77! I'll take my 120+ fairly dry climate any day. I use to work out there every year at the peak of the heat for fuel hot testing... I'd be out there over a month out at the proving grounds so I know the heat... every year the humidity was climbing... last time I was out there the humidity was up to 35*... no idea what it is now days.. with all the pools and and all the other things.. I have no clue what it is now... but its still way lower than here... 65% is a low day in the summer here.... but I had to work on it.. so I lost a few pounds LOL ...... Oh my turds... I just cant stand big boats.... I already have a boat.. but it floats..LOL
[Re: J_BODY]
#1895220
08/19/15 10:58 AM
08/19/15 10:58 AM
MR_P_BODY
Any plans on some 1/4 hits prior to Dragweek? Yeah....would like to get out next week... I have no idea on any of the settings on this car... I'm gonna start with my standard starting points.. maybe start at 14#-15# on the drag radials... I forgot yesterday to check my belts to see if they are still good
[Re: MR_P_BODY]
#1895262
08/19/15 12:05 PM
08/19/15 12:05 PM
Posts: 368 michigan
turbo toad
michigan
Mr P body where do you plan on testing it at? Im off work next weekend and would love to see that rampage in action. Its always been a dream of mine since the 80s when DC offered the rwd conversion kit for the fwd platform to do a car like one of yours.......
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: turbo toad]
#1895265
08/19/15 12:10 PM
08/19/15 12:10 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good-luck Mike and I hope all goes well.
[Re: turbo toad]
#1895280
08/19/15 12:35 PM
08/19/15 12:35 PM
MR_P_BODY
Mr P body where do you plan on testing it at? Im off work next weekend and would love to see that rampage in action. Its always been a dream of mine since the 80s when DC offered the rwd conversion kit for the fwd platform to do a car like one of yours....... If the next few days go well I'll be doing the Hines Drive cruise... I need to get some miles on it so the injection learns... then the following weekend I'll hit Lapeer to get some track time.... I forgot.. I still have to get OKed with the doc to go... I've been having dizzy spells after my by-pass surgery
[Re: MR_P_BODY]
#1895283
08/19/15 12:41 PM
08/19/15 12:41 PM
dartman366
Mt. Vernon, Ohio
Hope it all works out for you Mike, and I get the chance to read about you and the car in the publications, take care, be safe and most of all enjoy your trek.
[Re: dartman366]
#1895485
08/19/15 06:04 PM
08/19/15 06:04 PM
MR_P_BODY
Well I had it running most of the day and got the injection where it needs to be.... I also found a oil leak at the top of the pass side valve cover... it drips onto the lip of the intake.. very slow but its there..I'll pull that off and see whats hitting
