Finally Got It Fired.... AGAIN #1894589
08/18/15 05:54 PM
08/18/15 05:54 PM
MR_P_BODY Offline OP
I got it fired up and checked the trans... everything
seems to function fine... I had a few issues that I
screwed up on... I couldnt get fuel pressure on the
gauge... I messed up and put the lines on backwards at
the fender... changed that after loosening the fitting
and spraying fuel...still need to set the timing and hook
up the steering at the rack(I have to pull that to get the
headers in and out).... but it works/runs and the tires turn
in all gears and OD... now to give it a bath and a quick
check over
wave
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894593
08/18/15 05:57 PM
08/18/15 05:57 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Was the tranny locking up on you in OD?
Re: Finally Got It Fired.... AGAIN [Re: WO23Coronet] #1894602
08/18/15 06:05 PM
08/18/15 06:05 PM
It was last time... mess up on assembly... had too many clutch
disc in it and it couldnt release one set when the other
was suppose to come on... it just didnt have any clearance
to release... got it all figured out... finally... it goes
into OD nicely now... I want to get it out on the street
to check the governor shift points... I'm hoping they are
fairly low.. like shift to 2nd at 15 to 18 mph
wave
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894607
08/18/15 06:10 PM
08/18/15 06:10 PM
Az
Crizila Offline
Crizila  Offline
Az
check over
wave
up up beer wave
Fastest 300
Re: Finally Got It Fired.... AGAIN [Re: Crizila] #1894614
08/18/15 06:21 PM
08/18/15 06:21 PM
I want to make the Hines Drive cruise.. that will
be a good test run for it... thats this Saturday...
that will be about 125 miles round trip
wave
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894622
08/18/15 06:29 PM
08/18/15 06:29 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
wave
Are you sure you remember how to drive one of these hotrods lol
J/K glad to see you made progress and getting out there.
Re: Finally Got It Fired.... AGAIN [Re: Sammy] #1894634
08/18/15 06:40 PM
08/18/15 06:40 PM
wave
I hope I remember... if everything goes smoothly then yes
I should remember.. if not.. there might be a fire on the
side of the road
wave
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894658
08/18/15 07:01 PM
08/18/15 07:01 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Good to see your back on the road again Mike. Mine won't be leaving the garage this spring. Just hope to have engine built and off Dyno before cold weather gets here.
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894667
08/18/15 07:16 PM
08/18/15 07:16 PM
NC
barracuda man Offline
NC
glad your doing well mike.u have any pic of the ride?Mines still in the trailer with a broke rod.Just to hot to work on it now maybe oct i'ii get it out and have a look.
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894701
08/18/15 07:50 PM
08/18/15 07:50 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
side of the road
wave
lol...
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894715
08/18/15 08:04 PM
08/18/15 08:04 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Congratulations Mike! Hope it all goes well.
Re: Finally Got It Fired.... AGAIN [Re: barracuda man] #1894748
08/18/15 08:42 PM
08/18/15 08:42 PM
Believe me.. its been hot here.... but I didnt
have any choice if I want to make drag week.. I
have less than a month to get things sorted out..
and it hasnt been on the track yet... the humidity
here has been up there. along with close to 90*
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894790
08/18/15 09:26 PM
08/18/15 09:26 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Glad to know its running again. I hope to light off the new power plant this weekend. See you in St Louis
68 Barracuda Formula S 340
Re: Finally Got It Fired.... AGAIN [Re: Bad340fish] #1894798
08/18/15 09:30 PM
08/18/15 09:30 PM
I sure hope so... find out more in the next week
wave
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894801
08/18/15 09:31 PM
08/18/15 09:31 PM
Mich.
oldguy Offline
oldguy  Offline
Mich.
Looks nice
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894817
08/18/15 09:46 PM
08/18/15 09:46 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Looks Good Mike up
Glad to hear you got it together and running again. beer
Now go put some Miles on it drive
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894824
08/18/15 09:50 PM
08/18/15 09:50 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Looks real sharp, Mike. Just remember not to overdo it.
[image][/image]
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894869
08/18/15 10:34 PM
08/18/15 10:34 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The car looks very nice. Good job.
Re: Finally Got It Fired.... AGAIN [Re: TRENDZ] #1894887
08/18/15 10:46 PM
08/18/15 10:46 PM
This was what the front end looked like a month ago...
damn hard to find parts for a 2 door L-body or Rampage
this was a cherry picker failure(the cyl ram gave out
and bent and set the engine on the front end)
EDIT
this pic is after lifting the engine off the front
end... it was pretty much flat on the floor
wave
Re: Finally Got It Fired.... AGAIN [Re: MR_P_BODY] #1894943
08/18/15 11:20 PM
08/18/15 11:20 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Glad to hear she's back together, Mike! There's no quit in you, that's for sure!
Gone to the dark side with an LS3 powered '57 Chevy 210
