I got it fired up and checked the trans... everything
seems to function fine... I had a few issues that I
screwed up on... I couldnt get fuel pressure on the
gauge... I messed up and put the lines on backwards at
the fender... changed that after loosening the fitting
and spraying fuel...still need to set the timing and hook
up the steering at the rack(I have to pull that to get the
headers in and out).... but it works/runs and the tires turn
in all gears and OD... now to give it a bath and a quick
check over
