A body wiring harness #1893998
08/17/15 10:58 PM
08/17/15 10:58 PM
70duster340 Offline OP
Can anyone suggest a decent harness that is reasonable in cost? I would love to have an updated wiring harness that won't break the budget.
Thanks in advance!!!
Re: A body wiring harness [Re: 70duster340] #1894121
08/18/15 01:45 AM
08/18/15 01:45 AM
Nobody???
Re: A body wiring harness [Re: 70duster340] #1894124
08/18/15 01:51 AM
08/18/15 01:51 AM
I redid my 65 dart from scratch. set the old harness on the floor and soldered in 1 wire at a time on a new harness as I cut the old wire off of the old harness till the new one took shape and the old one dissapeared right next to it. I upped the gauges on some circuit. BE SURE to use the OE colors (including wires with colored tracers). there are companies that will sell you the exact lengths of any color/gauge you need. NAPA has the bulkhead terminals 725145/725147 (female/male premium brass 1/4" terminals). underhood is easy but forewarned under dash takes some doin (& this was on a bare bones 65 dart!) You asked for a new harness (recommendations) so here's a BTT for ya
Re: A body wiring harness [Re: 70duster340] #1894517
08/18/15 04:28 PM
08/18/15 04:28 PM
Thanks, Robert. Yeah, I would prefer to have a new harness. Even a good universal harness would satisfy me, as long as it is not too complicated to install.
Thanks for the BTT!
Re: A body wiring harness [Re: 70duster340] #1894712
08/18/15 08:01 PM
08/18/15 08:01 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Got mine from Classic Ind. and it worked great and looked good
Re: A body wiring harness [Re: 70duster340] #1894737
08/18/15 08:31 PM
08/18/15 08:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Let's see.....To sum things up you want
Low priced
Quality parts
Easy To install
Gee, that's not asking for much tonguue
Good luck! whistling
Re: A body wiring harness [Re: 70duster340] #1894951
08/18/15 11:28 PM
08/18/15 11:28 PM
I don't think that wanting an affordable part, no matter what it may be, is too much to ask.
Re: A body wiring harness [Re: 70duster340] #1894955
08/18/15 11:31 PM
08/18/15 11:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Define affordable (in dollars). Everybody has a different idea of what "affordable" is so you aren't going to get much (good) information when you ask such a subjective question. I'm not trying to pick on you, just giving it to you straight.
Re: A body wiring harness [Re: 70duster340] #1894972
08/18/15 11:46 PM
08/18/15 11:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
There is no such thing as an easy aftermarket wiring harness. The less expensive they are, the more difficult they are to install. Don't buy the cheapest kit you can find!
Plan on reusing your headlight switch connector, your ignition switch connector, your turn signal connector, and your dimmer switch connector. Most aftermarket wiring kits are GM based and won't come with Mopar switch connections.
I've done 3 of them now, all from different suppliers. Still looking for a "good one". Gene
Re: A body wiring harness [Re: poorboy] #1895005
08/19/15 12:31 AM
08/19/15 12:31 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I recently bought an Evans harness for a 70 Swinger and found a couple connections that needed re-crimping. If you buy any aftermarket new harness I recommend checking every connection. twocents I have not used a Ron Francis harness so I can't post a review on that one. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: A body wiring harness [Re: 70duster340] #1895035
08/19/15 12:57 AM
08/19/15 12:57 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Since we are talking quality......I have tried Evans and M&H (sold exclusively through Year One).
I would not use ANY other reproduction harness other than M&H on my cars. Yes, expensive (roughly $600.00 for a dash harness and an engine harness). Well worth it, cheap insurance, fits like original, goes in easy because it belongs there. No other way to go on a reproduction IMO.
If you have a decent original you can have JS Restorations restore it for you, SUPERB customer service and quality but I don't think he's accepting new work at this time.
twocents
Re: A body wiring harness [Re: 70duster340] #1895036
08/19/15 01:00 AM
08/19/15 01:00 AM
Originally Posted By 70duster340
Can anyone suggest a decent harness that is reasonable in cost? I would love to have an updated wiring harness that won't break the budget. Thanks in advance!!!
Your request sounded perfectly straight up/reasonable/feasable to me. From some of the posts regarding fitment/GM based etc I feel a bit better about doing mine from scratch but I hate to say this but I would not want to do it again but I did get it dead on perfect the way I wanted it
Re: A body wiring harness [Re: 70duster340] #1895299
08/19/15 12:58 PM
08/19/15 12:58 PM
I thought it did, too, Robert.
I don't mind doing some of the work myself, I just think that some of the harnesses out there are well overpriced. This is a project car, and I prefer to do some of the work myself. I guess I am asking for a good harness at a reasonable price that will be a good fit for my car.
Re: A body wiring harness [Re: 70duster340] #1895607
08/19/15 09:26 PM
08/19/15 09:26 PM
BTT
Re: A body wiring harness [Re: 70duster340] #1895650
08/19/15 10:43 PM
08/19/15 10:43 PM
the house on the left.
cogen80 Offline
cogen80  Offline
whatever you do stay away from that evans garbage. bad crimps all over those things.
go with a M&H sld by year one and i think classic.
Re: A body wiring harness [Re: 70duster340] #1895688
08/20/15 12:05 AM
08/20/15 12:05 AM
I will do that, and thanks for the advice!
