A engine oil pumps #189346
01/10/09 11:00 AM
01/10/09 11:00 AM
Finally a HUSKER again
Moparnut426 Offline OP
I am going to run just a run of the mill Melling HV oil pump in my 408, anyone on here object, and think It needs a better set up. I have had Melling pumps really do good fo rme, and I havent heard anyone on here say they are using anything "special" on their race stuff.
Just kicking stuff around.
Kasey
Re: A engine oil pumps [Re: Moparnut426] #189347
01/10/09 11:03 AM
01/10/09 11:03 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
What type pan are you running? A HV pump can empty a stock pan in a quarter of a mile.
Bill
Re: A engine oil pumps [Re: 340Cuda] #189348
01/10/09 11:22 AM
01/10/09 11:22 AM
Its a LARGE charlies aluminum pan, It holds 8 quarts I believe.
Kasey
Re: A engine oil pumps [Re: Moparnut426] #189349
01/10/09 01:26 PM
01/10/09 01:26 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The problem is there really isn't anything else out there. I know there are the Titan pumps, but they are over $800 the last I checked!!!
Re: A engine oil pumps [Re: dizuster] #189350
01/10/09 03:14 PM
01/10/09 03:14 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My stock pump gives me 30 at idle and 65 hot, i have a HV but it wouldn't fit under the stock style molidon pan.
Re: A engine oil pumps [Re: ademon] #189351
01/10/09 03:26 PM
01/10/09 03:26 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
heck, unless you get the right pump, it wont fit under their 8qt pan either.
You need to get the pump that used philips head screws that are countersunk in the cover and then grind down and edge slightly or it WILL hit the pan.
The pump that uses the hex head screws doesnt fit worth a damn and the screw heads will punch a hole in the pan. damhik
Re: A engine oil pumps [Re: aarcuda] #189352
01/10/09 04:04 PM
01/10/09 04:04 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
A place called precision takes the stock melling pump and blueprints it, and makes some minor mods to it.
I have one and think its a nice piece. They are well under 100 bucks if i remember right
http://www.precisionoilpumps.com/
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: A engine oil pumps [Re: aarcuda] #189353
01/10/09 04:10 PM
01/10/09 04:10 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
That's odd.... I build about 25 SB's a year & anything that has an internal pump uses the M72HV with the newer style 7/16" wrenching hex head bolts.... I've never had one hit the pan ever. Granted I could'nt tell you the last time I used a stock pan was though..... But I just did this 408 with the Milodon "Low Profile" pan & even it cleared....that was second one of those I've used.... we do bunch of Milodon 8 QT pans & Moroso 8 QT pans each year also.
I take the pumps apart & drill the outlet out to 1/2" & do a little hand radiusing inside it for little more volume & I usually modify oil pickup tubes as well.
Re: A engine oil pumps [Re: RyanJ] #189354
01/10/09 04:32 PM
01/10/09 04:32 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
this was on 2 different 340's. maybe the 360 cap is a different height but I am SURE i punched a hole thru 1 pan 10 years age and learned I needed the countersunk philips then.
then on my 416 build this summer, I had the same problem. I needed to grind the edge of the pump ever so slightly and dent the bottom of the pan.
Re: A engine oil pumps [Re: aarcuda] #189355
01/10/09 04:38 PM
01/10/09 04:38 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
and heres where it hit the pan. i had to ding it with a hammer slightly
Re: A engine oil pumps [Re: RyanJ] #189356
01/10/09 04:53 PM
01/10/09 04:53 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Ryan, how do you mod the pickup tube? Do you still feed the oil into the 'standard' pump inlet or do you use bottom feed pickups?
I'd like to use a 1/2" pickup but due to my center sump I don't think I'll have clearance for a bottom feed pickup - and I thought 'conventional' wisdom was that the M72HV does not have enough meat to bore out the standard pickup inlet point to 1/2".
Thanks!
Re: A engine oil pumps [Re: Gavin] #189357
01/10/09 05:37 PM
01/10/09 05:37 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
Damn! I dropped my change.............
Re: A engine oil pumps [Re: Gavin] #189358
01/10/09 05:54 PM
01/10/09 05:54 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Gavin, I leave the pump & end of pickup at 3/8" NPT but drill out the end of the pickups to .500" where they are welded to a more solid chunk of threaded round stock to thread into the pump. Takes a whole 30 seconds in the vice with a .500" drill bit do do something Milodon & Moroso should be doing....
aar: it has to be the pans you're using (factory style looks like), I do alot of both 360 & 340 factory blocks a year. It has nothing to do with the block or caps.... I've built every block in existence for the most part, X, R, R1, R1A, R2, R3, 340, 360, TA... never had one hit. All I use is the M72HV.... dunno, maybe you just have really bad luck.
Re: A engine oil pumps [Re: RyanJ] #189359
01/10/09 05:57 PM
01/10/09 05:57 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
BTW where are you getting the M72HV's with the flat head screws? The only ones I've seen like that were MP units. All the new Mellings I've bought in at least the past 4-5 years use the 7/16 head bolts. I hav'nt bought any MP's in long time. Every once in a while a customer will send one in to use on their engine that's when I see them.
Re: A engine oil pumps [Re: RyanJ] #189360
01/10/09 06:32 PM
01/10/09 06:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
All of the old pans I've seen were stock pans with the sump made deeper. A stock type pan will definately hit in the area's he's showing, but antyhing that was made off new tooling doesn't seem to have that problem...
Re: A engine oil pumps [Re: dizuster] #189361
01/10/09 06:53 PM
01/10/09 06:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have Milodon pans on my 340 and one for my 408, both motors have high volume pumps. I've had to work on both pans and pumps to get enough clearence. I busted a 8 quart moroso pan on my 340, the 7/16 hex heads hit. When I fitted the Moroso I used phillips bolts on the two rear bolts and still had to turn them down. I changed the hex bolts on the pump for my 408 also.
Re: A engine oil pumps [Re: dizuster] #189362
01/10/09 07:02 PM
01/10/09 07:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
aarcuda are you inverting pictures or something. The reason I ask your picture of the pump shows it's location on the rear drivers side of the engine. Which is correct. Then you show a pick of your pan with marks all around the rear corner passengers side of the engine. You either inverted your picture or was clearancing for something else.
I ran these pumps for years without any clearancing on many different pans. Now when I ran a 4.125 stroke with alluminum rods I had to space the pump off the cap with a .125" spacer. Then I simply put the pan on with no gasket. Taped on the pan to make clearance so the pan would fit. Then simply reinstall with gaskets. No problem.
Leon
Re: A engine oil pumps [Re: justinp61] #189363
01/10/09 07:03 PM
01/10/09 07:03 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Thank you
Ryan had me thinking i was nuts. I punched out a pan 8 years ago with the bolt heads. I was pissed because I knew they were touching the pan when I put it on but since Ive NEVER heard that there was a clearane issue, I figured I was making too much of it. i even came up with the theory that the bolt heads would dent the oil pan based and MAKE ther own room.
So I bolted it and tightened up the blt. then PANG! the head pushed thru.
I brazed it up and used an oil pump like this on.
I actually did try a regular hv melling (with the bolts) on this motor too that I built this summer. I felt it hit the pan and STOPPED. I knew I had to get another pump with the philips screws.
Amazingly and thankfully, my buddy hemityme had an old chrysler NOS one that he gave me...
Re: A engine oil pumps [Re: RyanJ] #189364
01/10/09 07:14 PM
01/10/09 07:14 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Sorry Ryan, bear with me, I must be a bit slow today .....you don't touch the 3/8" hole in the pump, but you mention both leaving the end of pickup at 3/8 and also drilling out the end of the pickup to 1/2, and welding the new stock which threads to the (3/8) pump. Could you run that past me again.........thanks!
Re: A engine oil pumps [Re: Leon441] #189365
01/10/09 07:14 PM
01/10/09 07:14 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Leon
no, its right. that the inside of the pan. turn it upside down and its rig.
i cant figure out why some people have no problems. i know what happened to me- twice
