Re: A engine oil pumps
[Re: dizuster]
#189350
01/10/09 03:14 PM
01/10/09 03:14 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
My stock pump gives me 30 at idle and 65 hot, i have a HV but it wouldn't fit under the stock style molidon pan.
[Re: ademon]
#189351
01/10/09 03:26 PM
01/10/09 03:26 PM
Posts: 15,489 the boonies
aarcuda
the boonies
heck, unless you get the right pump, it wont fit under their 8qt pan either.
You need to get the pump that used philips head screws that are countersunk in the cover and then grind down and edge slightly or it WILL hit the pan.
The pump that uses the hex head screws doesnt fit worth a damn and the screw heads will punch a hole in the pan. damhik
[Re: aarcuda]
#189352
01/10/09 04:04 PM
01/10/09 04:04 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
A place called precision takes the stock melling pump and blueprints it, and makes some minor mods to it. I have one and think its a nice piece. They are well under 100 bucks if i remember right http://www.precisionoilpumps.com/
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: aarcuda]
#189353
01/10/09 04:10 PM
01/10/09 04:10 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
That's odd.... I build about 25 SB's a year & anything that has an internal pump uses the M72HV with the newer style 7/16" wrenching hex head bolts.... I've never had one hit the pan ever. Granted I could'nt tell you the last time I used a stock pan was though..... But I just did this 408 with the Milodon "Low Profile" pan & even it cleared....that was second one of those I've used.... we do bunch of Milodon 8 QT pans & Moroso 8 QT pans each year also.
I take the pumps apart & drill the outlet out to 1/2" & do a little hand radiusing inside it for little more volume & I usually modify oil pickup tubes as well.
[Re: RyanJ]
#189356
01/10/09 04:53 PM
01/10/09 04:53 PM
Posts: 1,756 London, England
Gavin
London, England
Ryan, how do you mod the pickup tube? Do you still feed the oil into the 'standard' pump inlet or do you use bottom feed pickups? I'd like to use a 1/2" pickup but due to my center sump I don't think I'll have clearance for a bottom feed pickup - and I thought 'conventional' wisdom was that the M72HV does not have enough meat to bore out the standard pickup inlet point to 1/2".
Thanks!
[Re: Gavin]
#189358
01/10/09 05:54 PM
01/10/09 05:54 PM
RyanJ
moparts member
moparts member
State College, PA
Gavin, I leave the pump & end of pickup at 3/8" NPT but drill out the end of the pickups to .500" where they are welded to a more solid chunk of threaded round stock to thread into the pump. Takes a whole 30 seconds in the vice with a .500" drill bit do do something Milodon & Moroso should be doing.... aar: it has to be the pans you're using (factory style looks like), I do alot of both 360 & 340 factory blocks a year. It has nothing to do with the block or caps.... I've built every block in existence for the most part, X, R, R1, R1A, R2, R3, 340, 360, TA... never had one hit. All I use is the M72HV.... dunno, maybe you just have really bad luck.
[Re: dizuster]
#189362
01/10/09 07:02 PM
01/10/09 07:02 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
aarcuda are you inverting pictures or something. The reason I ask your picture of the pump shows it's location on the rear drivers side of the engine. Which is correct. Then you show a pick of your pan with marks all around the rear corner passengers side of the engine. You either inverted your picture or was clearancing for something else.
I ran these pumps for years without any clearancing on many different pans. Now when I ran a 4.125 stroke with alluminum rods I had to space the pump off the cap with a .125" spacer. Then I simply put the pan on with no gasket. Taped on the pan to make clearance so the pan would fit. Then simply reinstall with gaskets. No problem.
Leon
[Re: justinp61]
#189363
01/10/09 07:03 PM
01/10/09 07:03 PM
aarcuda
the boonies
I have Milodon pans on my 340 and one for my 408, both motors have high volume pumps. I've had to work on both pans and pumps to get enough clearence. I busted a 8 quart moroso pan on my 340, the 7/16 hex heads hit. When I fitted the Moroso I used phillips bolts on the two rear bolts and still had to turn them down. I changed the hex bolts on the pump for my 408 also.
Thank you
Ryan had me thinking i was nuts. I punched out a pan 8 years ago with the bolt heads. I was pissed because I knew they were touching the pan when I put it on but since Ive NEVER heard that there was a clearane issue, I figured I was making too much of it. i even came up with the theory that the bolt heads would dent the oil pan based and MAKE ther own room.
So I bolted it and tightened up the blt. then PANG! the head pushed thru.
I brazed it up and used an oil pump like this on.
I actually did try a regular hv melling (with the bolts) on this motor too that I built this summer. I felt it hit the pan and STOPPED. I knew I had to get another pump with the philips screws.
Amazingly and thankfully, my buddy hemityme had an old chrysler NOS one that he gave me...
[Re: RyanJ]
#189364
01/10/09 07:14 PM
01/10/09 07:14 PM
Gavin
London, England
Sorry Ryan, bear with me, I must be a bit slow today .....you don't touch the 3/8" hole in the pump, but you mention both leaving the end of pickup at 3/8 and also drilling out the end of the pickup to 1/2, and welding the new stock which threads to the (3/8) pump. Could you run that past me again.........thanks!
[Re: Leon441]
#189365
01/10/09 07:14 PM
01/10/09 07:14 PM
aarcuda
the boonies
Leon
no, its right. that the inside of the pan. turn it upside down and its rig.
i cant figure out why some people have no problems. i know what happened to me- twice
[Re: Gavin]
#189372
01/10/09 07:36 PM
01/10/09 07:36 PM
RyanJ
moparts member
moparts member
State College, PA
You're making it way too complicated..... take the Milodon or Moroso pickup & just run a .500" drill into the end of it where it threads into the pump. They're like .420" from moroso/milodon. That's it.... there's no wleding or tapping etc. You don't need 1/2" NPT inlet into your pump or pickup. A 3/8" NPT hole is larger than .500".....
I dunno why you guys are having pump/pan issues, obviously something is different between what you're using & what I'm using. Without having ever seen one in my hands that hit I can't really say what the deal is. All I can tell you is I've never had one hit which is odd seeing as how multiple people on here have had clearance issues, dunno.
[Re: Neil]
#189373
01/10/09 07:36 PM
01/10/09 07:36 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Maybe there are manfacturing differences . This pan fit like profanity reference deleted, the bolt holes had to be elongated on both sides, it's like the pan is out of square . If I ever buils another I'll use someone elses pan for sure.
[Re: aarcuda]
#189375
01/10/09 10:02 PM
01/10/09 10:02 PM
Posts: 189 long island new york
kingdust
i never had oil pump to pan clearance issues, ive built more than a few 340s ( not as much as ryan)but i did have a milodon pan that the bolt holes were'nt even close to lining up! sent it back to jegs and they sent me another one and that one worked. nothings ever perfect.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: justinp61]
#189382
01/11/09 12:07 PM
01/11/09 12:07 PM
Posts: 660 San Diego
formula S
San Diego
Pump #2.
I built a 360 over the summer and used a m72hv, and a stock pan that I got from mancini. No problems with fit, with that said the pump cover was cast differently, the screw pads on the pump cover were recessed. As far as oil pump and pickup modification on race engines, I disassemble the pump, drill the pickup out to 3/4", port and blend both suction and discharge sides of the pump. Then I use 3/4" O/D x.090 tubing to fab a pickup, then slide the pickup into the pump at least an inch, and braze it together this work really well.
[Re: formula S]
#189384
01/11/09 04:16 PM
01/11/09 04:16 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Here is what the top of my Mellings HV pump looks like. Bought last summer:
[Re: 69Cuda340S]
#189385
01/11/09 04:47 PM
01/11/09 04:47 PM
aarcuda
the boonies
ahaa!! Those bolts are countersunk A LOT. thats why some people arent having troubles with their (I bet).
The oil pump that caused me problems had a completely flat plate and that caused the hex heads to sit lower in the motor. I bet i wouldnt have had much (if any) problem with the pump in that picture. the one i had most trouble with look like :
