6 pack balancer #1893132
08/16/15 07:34 PM
08/16/15 07:34 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
is this a 'must have' if you are using 6 pack rods and a steel crank?? isn't neutral balance just that - neutral balance?
Re: 6 pack balancer [Re: mikemee1331] #1893167
08/16/15 08:57 PM
08/16/15 08:57 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Have the assembly internally balanced and use a standard balancer. Aftermarket or factory
Re: 6 pack balancer [Re: mikemee1331] #1893192
08/16/15 09:37 PM
08/16/15 09:37 PM
bethlehem pa
bethlehem pa
components were all balanced at a machine shop 25 years ago. engine has been assembled and running but the damper has slipped about 10 degrees over the years. i read the article on 440Source web site about this and they seem to say any balancer will work as long as it is for a steel crank.
Re: 6 pack balancer [Re: mikemee1331] #1893412
08/17/15 02:40 AM
08/17/15 02:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it has a 6pk balancer on it and it's been balanced then you need to replace it with another external balance balancer that is weighted the same.
Re: 6 pack balancer [Re: JohnRR] #1893472
08/17/15 10:42 AM
08/17/15 10:42 AM
an8sec70cuda Offline
iagree If it has a six pack balancer on it, then it is externally balanced. All the six pack rod motors were externally balanced from the factory and used a special balancer.
CHIP
'06 GMC 2500HD LBZ Duramax
