Torque specs #1892885
08/16/15 11:23 AM
08/16/15 11:23 AM
usa
csmopar Offline OP
csmopar  Offline OP
usa
Anyone know the factory torque specs for an Abody k frame? For the 4 bolts that hold it on?
Re: Torque specs [Re: csmopar] #1892961
08/16/15 02:15 PM
08/16/15 02:15 PM
OT before removing those bolts I would highly suggest drilling a small hole (4) in the subframe(s) and shooting some pb blaster in on the threads over several days so if the bolt is super tight (& alot are) thet you dont rip the female threads apart on the inside where you cant get to em to repair that damage. Cant say I've seen a spec for them but a person could get the torque spec for a grade 8 coarse thread bolt of that diameter & go with that. Here's a BTT for ya
Re: Torque specs [Re: csmopar] #1892999
08/16/15 03:52 PM
08/16/15 03:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I pretty sure E body is 150 ft lbs but I`m not sure on A body.
Re: Torque specs [Re: mopars4ever] #1893367
08/17/15 01:11 AM
08/17/15 01:11 AM
I am going to strickly WAG but I think they use the same bolts
