440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! #1892382
08/15/15 01:38 PM
08/15/15 01:38 PM
Uranus
strokerchall Offline OP
Uranus
I'm running 190-200 on highway and town.I been reading on other forums that guys have discovered the 440source housing to be very restrictive to the bottom hose.Any suggestions on an upgrade? The old engine ran fine with a mopar housing.
I called a 440source distributor in Edmonton,he said the housing has a definate prob with restriction but is easily cleaned up with a die grinder. He said my eddy high volume pump is good.
once you've stroked it,you'll wish you stroked it sooner
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1892390
08/15/15 01:44 PM
08/15/15 01:44 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
i have one on my 512 68 charger, has ac & the temps outside have been over 105 car runs 180 all day long.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: CSK] #1892396
08/15/15 01:53 PM
08/15/15 01:53 PM
all I can add is I purchased one of their blems that needs that port to be hogged out, I just ain't got around to checking it out yet to see if it is doable or if I bought a pig but I feel lucky! (& it should be an easy enough fix if the bit can get in there far enough)
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1892419
08/15/15 02:29 PM
08/15/15 02:29 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
If you read some more it turned out the pump was the issue later on.
The pump wasn't that effective.
I believe this has been solved already some time ago.
The housing was however also revised and a the passage was enlarged.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1892422
08/15/15 02:33 PM
08/15/15 02:33 PM
Uranus
Uranus
i've read guys fighting a heating prob ,change housing and prob solved.There were even posts that the factory MP housing flowed better?
The mancini housing was mentioned a couple times as an upgrade.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1892453
08/15/15 03:54 PM
08/15/15 03:54 PM
The Netherlands
The Netherlands
There doesn't seem anything wrong with the (any) housings as such, but I recall 440source did change their casting mostly to get rid of the negative vibe around their housing.
If I recall correctly, everyone agreed the passage was tiny, but it was never proven to cause such a restriction that it would cause overheating.
There are some differences in pump performance, which I've noticed myself as well, even just recently.
A modern design pump curved vane 'should' provide more flow, but most of the times the factory pumps with stamped vanes provide way more flow.
I think this might has something to do with the depth of the vanes. The modern curved vanes are simply not deep/high enough to displace enough water.
Besides that, also everyone agrees that the pump vanes need to be as close to the pumphousing as possible (unless a enclosed impeller type vane is used.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: BigBlockMopar] #1892490
08/15/15 05:00 PM
08/15/15 05:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I ran this "cat" pump on my eddie headed 440 with a 6 pak big cam, AC for 10 years. Worked fine But had super low miles on it with the aluminum housing I have. I got it like 13-15 years ago. I can't remember where I got(E bay?) the pump housing, but I think it's before 440 source stuff hit the shores? But I don't believe the housing has any bearing on any overheating issues, it's usually lack of air flow at low speeds or TUNING, imo. And use a thermostat.
I flushed my radiator last month and the water pump started leaking. I ordered up a standard stock volume water pump. It came with the "paddle" impeller. I bolted it in and it runs the exact same as the old pump. I have now driven it in Heath Ohio at the Mopar Nats 2 nights in slow traffic and up in Woodward this past week for 60-90 minutes of idling.
Stock mostly is where it's at when it comes to cooling, imo. grin
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1892640
08/15/15 10:12 PM
08/15/15 10:12 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
there was also an issue with using a 'stock' gasket instead of the one they recommend which is thicker. the pump can bind some in the housing.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1892688
08/15/15 11:35 PM
08/15/15 11:35 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Known issue...
Their original casting had smaller water ports...
In fact, rite now they are selling these parts @ a discount on their website..
"We have a limited supply of our 200-1079 Passenger side aluminum water pump housings which have been cast with a slightly smaller than normal lower water port.
We've used these on many engines without any problems, however because the ports are slightly smaller than normal, we are selling these as a "blem" item.
If desired, with a die grinder and carbide burrs, the passages could be opened up, similar to cylinder head porting.
A steal at this price, we've marked them down to over 50% OFF the normal price. Get them while they last. Once they are sold out, they are gone forever. $48.95 each..."
A friend ran 1 of these on his stroker 440, it ran hot...
Swapped it out for the Mopar performance part, tempeature dropped 10 degrees in So Cal traffic..
Just my $0.02... wink
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: Sinitro] #1892738
08/16/15 12:59 AM
08/16/15 12:59 AM
that's the one I got & it was ordered with other items so it was $49. I just check ed it & that port is definitely gonna need some porting & I got the scroll pump earlier & the vanes do look shallow on it EDIT part # had a B after the 9 (for blem)
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: RapidRobert] #1892968
08/16/15 02:28 PM
08/16/15 02:28 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
OK, lets look at what has been said. Over heating because of a smaller lower hose port. With that being said , how much smaller could it be? The lower hose is 1 3/4 " Most street cars run a thermostat or a restrictor which would restrict flow more than a half plugged pump housing. I would look at something else causing your problem.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: Sinitro] #1893082
08/16/15 06:20 PM
08/16/15 06:20 PM
The Netherlands
The Netherlands
Did the guy ever check the pump vane clearance against both housings?
Did he also change waterpumps?
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893107
08/16/15 07:03 PM
08/16/15 07:03 PM
Uranus
Uranus
I'll list my current cooling system:
-22" rad (i know its small) champion 3 core
-flex-alite 3300cfm
-non restrictive 165 thermostat
-eddy high volume pump
-440source housing
512 stroker
my old 500hp 440 ran cool without a shroud,mp pump housing,same rad
without a shroud the stroker got warm in traffic and about 170 on the highway
-I wish dodge would've had holes to bolt in a 26"
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! [Re: strokerchall] #1893155
08/16/15 08:13 PM
08/16/15 08:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why do you think that is a problem?
Don't be the exception.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893166
08/16/15 08:57 PM
08/16/15 08:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
-flex-alite 3300cfm
-440source housing
512 stroker
IMO there's nothing wrong with a 22" radiator. The problem I suspect is the fan. I'm thinking it is not moving enough air without a shroud. Put in a effective shroud and then maybe the electric fan might be enough. I doubt it. And put in a 180 or 195° thermostat, what are you doing with a 165?
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: Supercuda] #1893174
08/16/15 09:12 PM
08/16/15 09:12 PM
Uranus
Uranus
when i run it hard it pukes a lil fluid,i should prob add an over flow cannister
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: Challenger 1] #1893177
08/16/15 09:16 PM
08/16/15 09:16 PM
Uranus
Uranus
-flex-alite 3300cfm
-440source housing
512 stroker
i don't see how a diff thermostat would help,especially a hotter one.The elec fan would never stop .Currently i have the fan set to kick in around 190,on cooler days it will kick out quite often the car will run 180-185
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893187
08/16/15 09:29 PM
08/16/15 09:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what are the temps like where you live? i know Uranus is hot but as asked above, why the 165?
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893190
08/16/15 09:34 PM
08/16/15 09:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This is normal, that's why they have overflow tanks.
Your problem isn't your cooling system.
Running an engine with a 165 degree thermostat does nothing for it other than run the engine below efficient operating temps. If you were running a dedicated drag racer and turd polishing for the last tenth it might make sense. Anywhere else it's a bad choice. You'll note it does nothing for maximum temperature obtained.
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! [Re: strokerchall] #1893300
08/16/15 11:57 PM
08/16/15 11:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have the small passage 440 Source water pump housing on my 500 in. motor. Runs cool as a cucumber.
