440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!!
#1892382
08/15/15 01:38 PM
08/15/15 01:38 PM
Posts: 441 Uranus
strokerchall
Uranus
I'm running 190-200 on highway and town.I been reading on other forums that guys have discovered the 440source housing to be very restrictive to the bottom hose.Any suggestions on an upgrade? The old engine ran fine with a mopar housing.
I called a 440source distributor in Edmonton,he said the housing has a definate prob with restriction but is easily cleaned up with a die grinder. He said my eddy high volume pump is good.
once you've stroked it,you'll wish you stroked it sooner
Re: 440SOURCE WATER PUMP HOUSING....JUNK?
[Re: strokerchall]
#1892390
08/15/15 01:44 PM
08/15/15 01:44 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
i have one on my 512 68 charger, has ac & the temps outside have been over 105 car runs 180 all day long.
[Re: CSK]
#1892396
08/15/15 01:53 PM
08/15/15 01:53 PM
RapidRobert
all I can add is I purchased one of their blems that needs that port to be hogged out, I just ain't got around to checking it out yet to see if it is doable or if I bought a pig but I feel lucky! (& it should be an easy enough fix if the bit can get in there far enough)
[Re: strokerchall]
#1892422
08/15/15 02:33 PM
08/15/15 02:33 PM
Posts: 441 Uranus
strokerchall
Uranus
i've read guys fighting a heating prob ,change housing and prob solved.There were even posts that the factory MP housing flowed better? The mancini housing was mentioned a couple times as an upgrade.
[Re: strokerchall]
#1892688
08/15/15 11:35 PM
08/15/15 11:35 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Known issue... Their original casting had smaller water ports...In fact, rite now they are selling these parts @ a discount on their website.. "We have a limited supply of our 200-1079 Passenger side aluminum water pump housings which have been cast with a slightly smaller than normal lower water port. We've used these on many engines without any problems, however because the ports are slightly smaller than normal, we are selling these as a "blem" item. If desired, with a die grinder and carbide burrs, the passages could be opened up, similar to cylinder head porting. A steal at this price, we've marked them down to over 50% OFF the normal price. Get them while they last. Once they are sold out, they are gone forever. $48.95 each..." A friend ran 1 of these on his stroker 440, it ran hot... Swapped it out for the Mopar performance part, tempeature dropped 10 degrees in So Cal traffic.. Just my $0.02...
[Re: Sinitro]
#1892738
08/16/15 12:59 AM
08/16/15 12:59 AM
RapidRobert
that's the one I got & it was ordered with other items so it was $49. I just check ed it & that port is definitely gonna need some porting & I got the scroll pump earlier & the vanes do look shallow on it EDIT part # had a B after the 9 (for blem)
[Re: RapidRobert]
#1892968
08/16/15 02:28 PM
08/16/15 02:28 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
OK, lets look at what has been said. Over heating because of a smaller lower hose port. With that being said , how much smaller could it be? The lower hose is 1 3/4 " Most street cars run a thermostat or a restrictor which would restrict flow more than a half plugged pump housing. I would look at something else causing your problem.
[Re: Sinitro]
#1893082
08/16/15 06:20 PM
08/16/15 06:20 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
A friend ran 1 of these on his stroker 440, it ran hot... Swapped it out for the Mopar performance part, tempeature dropped 10 degrees in So Cal traffic.. Did the guy ever check the pump vane clearance against both housings? Did he also change waterpumps?
[Re: strokerchall]
#1893107
08/16/15 07:03 PM
08/16/15 07:03 PM
Posts: 441 Uranus
strokerchall
Uranus
I'll list my current cooling system: -22" rad (i know its small) champion 3 core -flex-alite 3300cfm -non restrictive 165 thermostat -eddy high volume pump -440source housing 512 stroker
my old 500hp 440 ran cool without a shroud,mp pump housing,same rad
without a shroud the stroker got warm in traffic and about 170 on the highway
-I wish dodge would've had holes to bolt in a 26"
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!!
[Re: strokerchall]
#1893155
08/16/15 08:13 PM
08/16/15 08:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I'm running 190-200 on highway Why do you think that is a problem?
[Re: strokerchall]
#1893166
08/16/15 08:57 PM
08/16/15 08:57 PM
Challenger 1
Cincinnati, Ohio
-I wish dodge would've had holes to bolt in a 26" IMO there's nothing wrong with a 22" radiator. The problem I suspect is the fan. I'm thinking it is not moving enough air without a shroud. Put in a effective shroud and then maybe the electric fan might be enough. I doubt it. And put in a 180 or 195° thermostat, what are you doing with a 165?
[Re: Supercuda]
#1893174
08/16/15 09:12 PM
08/16/15 09:12 PM
Posts: 441 Uranus
strokerchall
Uranus
I'm running 190-200 on highway Why do you think that is a problem? when i run it hard it pukes a lil fluid,i should prob add an over flow cannister
[Re: Challenger 1]
#1893177
08/16/15 09:16 PM
08/16/15 09:16 PM
Posts: 441 Uranus
strokerchall
Uranus
-I wish dodge would've had holes to bolt in a 26" IMO there's nothing wrong with a 22" radiator. The problem I suspect is the fan. I'm thinking it is not moving enough air without a shroud. Put in a effective shroud and then maybe the electric fan might be enough. I doubt it. And put in a 180 or 195° thermostat, what are you doing with a 165? i don't see how a diff thermostat would help,especially a hotter one.The elec fan would never stop .Currently i have the fan set to kick in around 190,on cooler days it will kick out quite often the car will run 180-185
[Re: strokerchall]
#1893190
08/16/15 09:34 PM
08/16/15 09:34 PM
Supercuda
About to go away
About to go away
up yours
I'm running 190-200 on highway Why do you think that is a problem? when i run it hard it pukes a lil fluid,i should prob add an over flow cannister This is normal, that's why they have overflow tanks. Your problem isn't your cooling system. Running an engine with a 165 degree thermostat does nothing for it other than run the engine below efficient operating temps. If you were running a dedicated drag racer and turd polishing for the last tenth it might make sense. Anywhere else it's a bad choice. You'll note it does nothing for maximum temperature obtained.
[Re: strokerchall]
#1893301
08/16/15 11:57 PM
08/16/15 11:57 PM
Posts: 441 Uranus
strokerchall
Uranus
The 165 was in it,it never runs at 165 so not big deal.The minimum heat it has ever run was 180. I'm going to get a overflow can. Also I believe the reason the car runs close to 200 on the highway is the 4:10 gears,runs at 3300 rpm at 60mph
[Re: BigBlockMopar]
#1893305
08/17/15 12:01 AM
08/17/15 12:01 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
A friend ran 1 of these on his stroker 440, it ran hot... Swapped it out for the Mopar performance part, tempeature dropped 10 degrees in So Cal traffic.. Did the guy ever check the pump vane clearance against both housings? Did he also change waterpumps? Exactly.
[Re: strokerchall]
#1893310
08/17/15 12:03 AM
08/17/15 12:03 AM
BSB67
Prospect, PA
The 165 was in it,it never runs at 165 so not big deal.The minimum heat it has ever run was 180. I'm going to get a overflow can. Also I believe the reason the car runs close to 200 on the highway is the 4:10 gears,runs at 3300 rpm at 60mph Why is it puking coolant at 200°? Is your gauge wrong?
[Re: BSB67]
#1893316
08/17/15 12:07 AM
08/17/15 12:07 AM
Posts: 441 Uranus
strokerchall
Uranus
The 165 was in it,it never runs at 165 so not big deal.The minimum heat it has ever run was 180. I'm going to get a overflow can. Also I believe the reason the car runs close to 200 on the highway is the 4:10 gears,runs at 3300 rpm at 60mph Why is it puking coolant at 200°? Is your gauge wrong? the fluid obviously expands,202 is the boiling point of water.The fluid level is down about 3/4" every week or so,depending on outside temp.I've only ever seen it drip a little.
[Re: BSB67]
#1893337
08/17/15 12:35 AM
08/17/15 12:35 AM
RapidRobert
I have the small passage 440 Source water pump housing on my 500 in. motor. Runs cool as a cucumber. I like hearing that! & you want no less than a 180 stat in there to get the eng above that cold/high wear window AS FAST as possible. Yes you are getting above 180 (with time) but you wanna be there ASAP & you get that with the stat being closed
[Re: BSB67]
#1893416
08/17/15 02:44 AM
08/17/15 02:44 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Boiling point of water is 212°
With the correct radiator cap and antifreeze, it is like 240° ^^^ and the 165 stat is open all the time once warmed up. Coolant has no time to lose heat passing right through the radiator. He might find a 195 could hold it right around the number.
I want my fair share
[Re: SomeCarGuy]
#1893444
08/17/15 05:23 AM
08/17/15 05:23 AM
BigBlockMopar
The Netherlands
Coolant has no time to lose heat passing right through the radiator. There's that myth again. If so, then why would the same coolant have enough time in the engine to take up all the heat? If a 165 stat is used and temps still rise above that all the time, it simply means the radiator/coolingsystem is not up to the task of cooling the engine, or the engine is not running efficiently enough.
[Re: BigBlockMopar]
#1894028
08/17/15 11:24 PM
08/17/15 11:24 PM
Posts: 5,445 So Cal
Sinitro
So Cal
A friend ran 1 of these on his stroker 440, it ran hot... Swapped it out for the Mopar performance part, tempeature dropped 10 degrees in So Cal traffic.. Did the guy ever check the pump vane clearance against both housings? Did he also change waterpumps? He is running the same water pump.. Just my $0.02...
[Re: BSB67]
#1894031
08/17/15 11:27 PM
08/17/15 11:27 PM
Posts: 5,445 So Cal
Sinitro
So Cal
I have the small passage 440 Source water pump housing on my 500 in. motor. Runs cool as a cucumber. But whats the average temperature in Prospect, PA? Today in SoCal it hit 109 degrees.. Just my $0.02...
[Re: strokerchall]
#1894075
08/18/15 12:29 AM
08/18/15 12:29 AM
Posts: 441 Uranus
strokerchall
Uranus
its an 07 housing,so i think its the one with the restriction prob
[Re: Sinitro]
#1894125
08/18/15 01:53 AM
08/18/15 01:53 AM
BSB67
Prospect, PA
I have the small passage 440 Source water pump housing on my 500 in. motor. Runs cool as a cucumber. But whats the average temperature in Prospect, PA? Today in SoCal it hit 109 degrees.. Just my $0.02... The average temp in Prospect Pa is not 109°F, nor is it in So Cal. The car runs fine in the low 90°s, but I prefer to not drive it when it is that hot. So the overheating only occurs at over 100°?
