Swing-out bars / Pro-Street door bars #189231
01/10/09 05:42 AM
01/10/09 05:42 AM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
How picky are most tech guys about either of these things?
ET's in the Low 11's high 10's
Re: Swing-out bars / Pro-Street door bars [Re: topbrent] #189232
01/10/09 11:15 AM
01/10/09 11:15 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Not sure about picky, but they are passable in the NHRA rule book. Mines out in the garage right now. Not sure what the et's are that they can be used in.
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Swing-out bars / Pro-Street door bars [Re: topbrent] #189233
01/10/09 11:22 AM
01/10/09 11:22 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
these are mine, suposed to cert to 8.50's
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Swing-out bars / Pro-Street door bars [Re: topbrent] #189234
01/10/09 11:25 AM
01/10/09 11:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Swing out bars are legal, the pro street bars I don't know about. The pro street bars IMHO are designed to fail in a roll over, the bends will allow them to fold up.
Re: Swing-out bars / Pro-Street door bars [Re: justinp61] #189235
01/10/09 12:17 PM
01/10/09 12:17 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
the prostreet bars were in the blue camaro at drag week 06
Mopar Performance
Re: Swing-out bars / Pro-Street door bars [Re: moparniac] #189236
01/10/09 12:56 PM
01/10/09 12:56 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
My cage builder didn't want to even put a slight bend in the door bars for the arm rests
I'd be real leery about bars with those bends. You'd be just as well having no bars at all.
Re: Swing-out bars / Pro-Street door bars [Re: topbrent] #189237
01/10/09 04:16 PM
01/10/09 04:16 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Mine passed inspection for division 3 cert.for 7.50. I think the rules have changed since then and now 8.50. They are also removeable.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Swing-out bars / Pro-Street door bars [Re: Hemi Allstate] #189238
01/10/09 04:21 PM
01/10/09 04:21 PM
Mt. Eden Ky.
Mt. Eden Ky.
Another pic, that shows the front mount.
1996 Ram 1500 Sport
1968 road runner
Re: Swing-out bars / Pro-Street door bars [Re: Hemi Allstate] #189239
01/10/09 06:18 PM
01/10/09 06:18 PM
Mt. Eden Ky.
Mt. Eden Ky.
Here is a better picture.
1996 Ram 1500 Sport
1968 road runner
Re: Swing-out bars / Pro-Street door bars [Re: Hemi Allstate] #189240
01/10/09 07:10 PM
01/10/09 07:10 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
so the prostreet door bars wont pass tech....
Mopar Performance
Re: Swing-out bars / Pro-Street door bars [Re: moparniac] #189241
01/10/09 10:57 PM
01/10/09 10:57 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
My bar looks like Kam Kuda and it is cert to 8.50. Don't think the pro street bar would cert.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: Swing-out bars / Pro-Street door bars [Re: brktracr] #189242
01/11/09 12:20 AM
01/11/09 12:20 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You must brace the Pro Street bar.
The idea of a door bar is to protect from side impact.
An added feature of a good door bar installation is added support to the main hoop and chassis.
A swing out bar does not accomplish this.
A pro street bar will push in during side impact which does not protect the driver. If you brace the bar from the bend at the drivers thigh back to the bottom of the main hoop you are improving the issue.
I ran my own version of a pro street door bar on my first cage. It only had one bend in it. I was required to install the brace just mentioned to make it legal. I am a big guy and have found it is a bad compromise when you try alter the door bar from just a straight door bar. The door bars I install are X'ed and can be done to have more clearance for driver entry with full cages than most than a lot of single door bars on 6 point roll bars.
Leon
Re: Swing-out bars / Pro-Street door bars [Re: Leon441] #189243
01/11/09 03:05 AM
01/11/09 03:05 AM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
Leon
Would the pro-street door bar brace be something like this?
Re: Swing-out bars / Pro-Street door bars [Re: topbrent] #189244
01/11/09 05:19 PM
01/11/09 05:19 PM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
Problem with most bent swingout bars is they dont pass by the driver midway between the shoulder and elbow which is the requirement. The one Topbrent shows appears to have that problem. Also in that photo the main hoop crossbar appears too high. Rule says shoulder high to 4" below shoulder. Back of seat also needs to be braced to the crossbar.
Re: Swing-out bars / Pro-Street door bars [Re: Stewart] #189245
01/11/09 05:32 PM
01/11/09 05:32 PM
My A/FX coronet is cert. 8.50...It has a swing bar but is setup in the manner Stewart listed above.
