Alternator windings Burn spot #1889888
08/11/15 11:00 PM
08/11/15 11:00 PM
michigan
440whiteboy Offline OP
michigan
must be time for a new alternator now that I noticed a hot burn spot in the lower windings. I would think that this cannot be normal?
BTW - engine is off after a few minutes in this picture!
They only see Stars...
when hit by a Mopar!
Re: Alternator windings Burn spot [Re: 440whiteboy] #1890027
08/12/15 01:58 AM
08/12/15 01:58 AM
Is that glowing!
Re: Alternator windings Burn spot [Re: RapidRobert] #1890229
08/12/15 01:30 PM
08/12/15 01:30 PM
dogdays Offline
dogdays  Offline
Looks like either a phase-to-phase or phase-to-ground short. It may be possible to separate the connection that isn't supposed to be there and reinsulate with insulating varnish. Or you could just get a different one.....
R.
