my 67 gtx size of tires and rims #1889552
08/11/15 03:41 PM
08/11/15 03:41 PM
ny
marcjames Offline OP
ny
can any one help me with how big of tires I can put on my car and some help with backspacing I would like cragers and 265 60 15 will these sizes work without any issues thanks 1967 stock gtx
Re: my 67 gtx size of tires and rims [Re: marcjames] #1889822
08/11/15 10:00 PM
08/11/15 10:00 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've never seen a 265/60-15; Only 255's & 275's, but assuming they exist: with perfect backspacing on a 7" rim, they should barely fit.
My car has completely stock fenderwells, and trim (no rolling). I run 255/60-15's on 15x7 steelies with 4-1/4" backspacing, and they fit really well. I also have a set of 245/60-15's a set of 8" rims with 4-1/4" backspacing, and that combo fits, but they're much tighter. I plan on seeing if the 255's will fit on the 15x8 rims, but my sense is I'm going to have to cut or roll the lips a little.
The key is rim size and backspacing. Perfect backspacing seems to be what the steelies are: 4-1/4" bs / 7" rim; This would equate to 4-3/4" bs on an 8" rim.
Re: my 67 gtx size of tires and rims [Re: marcjames] #1889988
08/12/15 12:58 AM
08/12/15 12:58 AM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I had 275's on this car.. They were very tight. They rubbed the inner fenders on corners with more then two people in the car. The wheel lips had been shaved and removed by a previous owner. 4 1/2" backspacing on 8" wheels. Kevin
71 gtx.....
Re: my 67 gtx size of tires and rims [Re: sleddinfool] #1890479
08/12/15 07:34 PM
08/12/15 07:34 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
I had 255/60 15s mounted on magnum rims w/ 4 1/2" backspacing. They were a pita. Cornering hard had the sidewalls grinding into the chrome molding & inner wheel lip to the point where the tires were getting cut. Taking them off was another pita. Couldn't get the tires off w/o major jacking up of car & deflating tires. As stated earlier, two people in the car, weight in the trunk, tires hit everywhere in the wheel well. Went back to 235/60s. Much happier.
Re: my 67 gtx size of tires and rims [Re: marcjames] #1890536
08/12/15 08:55 PM
08/12/15 08:55 PM
Puyallup, WA
Puyallup, WA
My 255's have never touched the fenderwells, and go on & off the car easy enough. I suppose every combo is different. Old worn out springs may let the rear end travel laterally???
Re: my 67 gtx size of tires and rims [Re: StealthWedge67] #1890685
08/13/15 12:17 AM
08/13/15 12:17 AM
Colorado
67plymouthman Offline
Colorado
I don't have any issues with 255s on a 15x7. They look real nice on 67s.
Re: my 67 gtx size of tires and rims [Re: marcjames] #1910548
09/11/15 02:26 PM
09/11/15 02:26 PM
ny
ny
hey thanks for the help you guys
Re: my 67 gtx size of tires and rims [Re: StealthWedge67] #1910552
09/11/15 02:34 PM
09/11/15 02:34 PM
ny
ny
hi thanks for your help is that for the rear tires how about the front thanks mark
Re: my 67 gtx size of tires and rims [Re: 67plymouthman] #1910554
09/11/15 02:36 PM
09/11/15 02:36 PM
ny
ny
hi thanks what tire size do you use on the front any backspacing on the rear thanks mark
Re: my 67 gtx size of tires and rims [Re: marcjames] #1910625
09/11/15 04:47 PM
09/11/15 04:47 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
I have run 10.7 inch section width tires on the back of my 67 Plymouth. There was a good deal of clearance, but I had some rubbing issues, which I later realized my axle end play was WAY off, and I think that had alot to do with it. These were on 15x7 wheels with 4 inch backspacing, another 1/4-1/2 inch backspacing would have been perfect. I do have Super Stock springs though.
Re: my 67 gtx size of tires and rims [Re: GTX MATT] #1910694
09/11/15 07:12 PM
09/11/15 07:12 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
225 60 15 on 7" wheels with 4" back space on front
245 60 15 on 8" wheels with 5 1/4" backspace..
One side rubbed on the inside fender well ( rear).. I had to put a 1/8" spacer on it.. No problems with front
Rear sway bar REALLY helped, Firm Feel brand.. Stock wheel wells.
