Dome lamp won't turn off #1889200
08/11/15 12:13 AM
08/11/15 12:13 AM
BigAg Offline OP
BigAg  Offline OP
Playing around with the new wiring harness on my 71 charger and i can't get the dome light to turn off. I have the rally eye dash and it looks like the way you should turn on the dome light would be through the Headlamp switch? Would it be right that the dash light and the dome light would be tied to the same switch?
Re: Dome lamp won't turn off [Re: BigAg] #1889216
08/11/15 12:41 AM
08/11/15 12:41 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Yes. Turning the headlight switch knob/dash-dimmer rheostat all the way to the full bright stop, turns on the dome light.
Re: Dome lamp won't turn off [Re: BigAg] #1889397
08/11/15 11:52 AM
08/11/15 11:52 AM
pa.
dan9 Offline
dan9  Offline
pa.
Also check the door switches to see if they are adjusted properly and that you have the correct style bulb.
