New 440 for 1979 "300" painted and ready for install. #1888398
08/09/15 10:52 PM
08/09/15 10:52 PM
Affton MO
Q
qwkmopardan Offline OP
Q
Affton MO
4.07" bore--4.250" stroke--268* at .050 x .560" lift Racer Brown solid flat tappet cam--11.75 to 1 CR--nicely ported 587 production cyl heads-- Victor 340 intake--1000cfm carb--1 3/4" hooker headers. Should make 1.6 HP per C.I. Actually ended up 442 C.I. because piston manufacturer made pistons for 4.07" bore instead of 4.06" bore, as I ordered a similar set for a 340 based engine at .030" over the same time I ordered pistons for this engine. 360 block for this project plenty thick enough to go .100 O.S.
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888443
08/09/15 11:21 PM
08/09/15 11:21 PM
Affton MO
Q
Q
Affton MO
Going in this car.
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888464
08/09/15 11:49 PM
08/09/15 11:49 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By qwkmopardan
Going in this car.
Very cool!! What's your ET goal?
Fastest 300
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888487
08/10/15 12:20 AM
08/10/15 12:20 AM
Idaho
LaRoy Engines Offline
Idaho
Looks pretty. So, after you dyno it, log back in and tell us how close you came to that 707 HP. That should be a record for 587 heads!
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888505
08/10/15 12:56 AM
08/10/15 12:56 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dan is the block filled?
Re: New 440 for 1979 "300" painted and ready for install. [Re: LaRoy Engines] #1888523
08/10/15 01:22 AM
08/10/15 01:22 AM
Affton MO
Q
Q
Affton MO
I'm sure there are not many 440 c.i. sm blocks with 587 heads so I'm traveling through uncharted waters.
However the 418 c.i. engine in my Demon has been 9.68 at 136.XX mph. Weighs 3050lbs. Same head castings with a little less flow, with a slightly bigger camshaft and a little more squeeze, but 24 c.i. smaller. 670 +/- HP. 670/418 = 1.603 HP per C.I.
Will not put it on a dyno but the car will let me know. The "300" weighs 4000lbs and should put it solid in 10 second zone. 650 hp would make it run 10.70s, 700hp would be 10.40s. We will find out soon enough.
Re: New 440 for 1979 "300" painted and ready for install. [Re: justinp61] #1888529
08/10/15 01:28 AM
08/10/15 01:28 AM
Affton MO
Q
Q
Affton MO
No, not filled. Car will be street driven.
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888663
08/10/15 11:25 AM
08/10/15 11:25 AM
Idaho
Idaho
Well dog-gone-it, I think that is really something. Love it when someone can do that with old iron heads.
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888683
08/10/15 12:03 PM
08/10/15 12:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
up What are the holes in the oil passage in the lifter galley on the drivers side of the block?
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888705
08/10/15 12:34 PM
08/10/15 12:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks stock to me............... biggrin thumbs
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888709
08/10/15 12:39 PM
08/10/15 12:39 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
This is cool!
Sheldon
Sheldon
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888758
08/10/15 01:48 PM
08/10/15 01:48 PM
P
Porter67 Offline
Porter67  Offline
P
Whatever it makes thats a cool build, what do you feel your shift points will be with that cam? Could you explain the lifter valley mods?
Ive seen some heads like those go 290 or so and from my own exp. 420-440 inches might as well be 400 inches as the 420-440 area just cant breath enough, but ive been wrong before.
Nice looking car its going into as well.
Re: New 440 for 1979 "300" painted and ready for install. [Re: justinp61] #1888775
08/10/15 02:27 PM
08/10/15 02:27 PM
Affton MO
Q
Q
Affton MO
Oil drainback. There is a 3/4" hole in camshaft thrustplate. Hard acceleration oil stays up top, anytime else, oil drains through the old lifter oil galley. Engine in "300" now,[408c.i.] has all the same junk. 20000+ miles, zero problems, Demon , same way, 1900+ passes, no problems.
Re: New 440 for 1979 "300" painted and ready for install. [Re: Porter67] #1888786
08/10/15 02:38 PM
08/10/15 02:38 PM
Affton MO
Q
Q
Affton MO
6700/6800 shift. I will have to experiment as it may be better lower. Torque should be very good on this engine.
Oil control. Hard acceleration oil stays up top, anytime else, oil drains through the old lifter oil galley. Engine in "300" now,[408c.i.] has all the same junk. 20000+ miles, zero problems, Demon , same way, 1900+ passes, no problems.
"300" has already been 11.60s at 116mph with a 408 with a lot less porting and camshaft. Engine in car now makes around 525HP.
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1888867
08/10/15 04:00 PM
08/10/15 04:00 PM
Az
Crizila Offline
Crizila  Offline
Az
Be prepared for wrinkled 1/4 panels near the "B" pillar area unless you do something with the middle of the car ( cage / subframe connectors). You will definitely be in the NHRA mandatory cage range anyway.
Fastest 300
Re: New 440 for 1979 "300" painted and ready for install. [Re: Crizila] #1888945
08/10/15 05:48 PM
08/10/15 05:48 PM
Affton MO
Q
Q
Affton MO
Going for a 6 point roll bar as soon as it runs. Also boxing the leaf spring mounts and connecting frames. Full cage not needed until 9.99 and quicker
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1889048
08/10/15 08:32 PM
08/10/15 08:32 PM
FastOne Offline
FastOne  Offline
I ported a set of 915 J heads for a 422 ci stroker, used the MP 296 mechanical cam with Strip Dominator manifold, the torque was insane
I'm watching this with great interest, car looks nice
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1889057
08/10/15 08:55 PM
08/10/15 08:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
wow I just don't see 650hp out of that combo. if you do get it i am junking my ported indy 360-1s and getting me some factory heads.
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1889100
08/10/15 10:22 PM
08/10/15 10:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's what I figured. I'm sure it'll run hard, all your stuff does. beer
Re: New 440 for 1979 "300" painted and ready for install. [Re: qwkmopardan] #1889574
08/11/15 04:27 PM
08/11/15 04:27 PM
St. Louis Mo. USA
P
Pleaz Offline
Pleaz  Offline
P
St. Louis Mo. USA
Looks good Dan,cant wait to see it in action.
