Head Gasket to fit 383 bore size? #1887670
08/08/15 09:20 PM
08/08/15 09:20 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Hi. I have been looking but haven't seen any head gaskets that are sized to fit the bore size. The Felpros I have have a bore opening of 4.512" . My bore in my 383 is 4.28".
Surely there is a gasket made to properly fit a .030 over 383 bore? I would prefer not having that little space between the block and head caused by this Felpro gasket to trap gases, and screw up the flame travel.
Thanks.
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887737
08/08/15 10:51 PM
08/08/15 10:51 PM
AndyF Online content
AndyF  Online Content
Depends which heads you are using. The head gasket needs to fit the chamber in the head not just the cylinder. There are a lot of different head gaskets with a lot of different bore sizes available.
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887768
08/08/15 11:20 PM
08/08/15 11:20 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Great! Who sells them and can provide the correct one?
Thanks.
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887772
08/08/15 11:24 PM
08/08/15 11:24 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
here are a few gaskets that will fit
http://www.summitracing.com/search/part-type/head-gaskets/make/dodge/engine-size/6-3l-383/engine-family/mopar-big-block-b?N=4294924325%2B4294883973&SortBy=Default&SortOrder=Ascending
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887829
08/09/15 12:26 AM
08/09/15 12:26 AM
Here is a picture out of my big block book which shows a few of the gaskets available. If you're new to big blocks you might want to start out by reading a few of the books available.
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887836
08/09/15 12:51 AM
08/09/15 12:51 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Thanks. But all those on the Summit pages show a 4.38" bore (which I really doubt is true). I want a 4.28" bore.
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887840
08/09/15 12:56 AM
08/09/15 12:56 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
One thing I just thought about, I suppose the bore opening size would shrink a bit when tightening the head down, as the material is squeezed out of shape. I don't know how much though. It would depend on several things.
Again, the openings in my Felpro gaskets measure 4.512". If someone has some gaskets that you can measure, I would like to know the bore opening diameter. Also, to get the opening diameter of some used gaskets would be interesting.
Thoughts?
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887886
08/09/15 02:30 AM
08/09/15 02:30 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1887985
08/09/15 12:48 PM
08/09/15 12:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Why do you doubt the truth of them listing 4.380" bore on those gaskets?
Ya know, using a 4.380" bore gasket on a 4.280" bore is only going to reveal .050" of the deck.
What are you splitting hairs on?
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1888140
08/09/15 05:12 PM
08/09/15 05:12 PM
I doubt that you want that small of a bore size. Most of the small bore gaskets won't work with aftermarket heads. You need to take a look at the cylinder head chapter in the book. You're focused on the wrong thing, the cylinder bore size isn't the most important factor when picking a head gasket.
Re: Head Gasket to fit 383 bore size? [Re: AndyF] #1888317
08/09/15 09:56 PM
08/09/15 09:56 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I always run the felpro 1009's. There is a Mopar part number to order a pair for like $60. They work perfect for 383 but too small for 400.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1888388
08/09/15 10:48 PM
08/09/15 10:48 PM
The 1009 is a small bore gasket and it won't fit a lot of heads that have been CNC ported. The CNC chamber work opens up the chamber past the gasket opening.
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1888553
08/10/15 02:03 AM
08/10/15 02:03 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
FYI, I am using stock heads.
The gaskets I have here, Fel-pro 8915PT, measure 4.512 in the opening. I don't know what the compressed diameter would be.
69dart, that's good to know. Though the spec on the 1009 says 4.410" opening, which is larger than all those ones listed in that Summit link provided above (4.380").
Re: Head Gasket to fit 383 bore size? [Re: lahatte] #1888764
08/10/15 01:56 PM
08/10/15 01:56 PM
If you're using stock cast iron heads then just use a set of stock steel shim gaskets.
Re: Head Gasket to fit 383 bore size? [Re: AndyF] #1888819
08/10/15 03:14 PM
08/10/15 03:14 PM
Mopar use to sell two different versions of there beaded steel head gaskest for the wedge motors, one for the 361,383,413 and 426W motors that was .022 thick with the smaller bore size for those motors. The other larger bore size was for the 440 , it was .017 thick so maybe the engineers reduce the thickness on those to help keep the compression up confused shruggy Try seeing if any of the vendors out there still have any of the original head gaskest for the smaller bore motors up
