Re: Head Gasket to fit 383 bore size?
[Re: lahatte]
#1887985
08/09/15 11:48 AM
08/09/15 11:48 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Thanks. But all those on the Summit pages show a 4.38" bore (which I really doubt is true). I want a 4.28" bore.
Why do you doubt the truth of them listing 4.380" bore on those gaskets? Ya know, using a 4.380" bore gasket on a 4.280" bore is only going to reveal .050" of the deck. What are you splitting hairs on?
[Re: lahatte]
#1888140
08/09/15 04:12 PM
08/09/15 04:12 PM
Posts: 31,336 Oregon
AndyF
I doubt that you want that small of a bore size. Most of the small bore gaskets won't work with aftermarket heads. You need to take a look at the cylinder head chapter in the book. You're focused on the wrong thing, the cylinder bore size isn't the most important factor when picking a head gasket.
