Float problems on 6 pack #1887895
08/09/15 03:30 AM
08/09/15 03:30 AM
South San Francisco, Ca
70sixpkrt Offline OP
2 weeks a go I put a new gas tank and sending unit. Last week my rear carb was coughing up gas so I pulled the needle and seat and cleaned it. Today it was surging on the freeway. I got home and checked the sight plug. Gas was pouring out of the sight hole. I adjusted the float down a little and no gas was coming out of the hole. Not even a dribble. This was with car off and shaking the car a little with my hip. So I adjusted the float a tad. Now gas is pouring out of the sight hole again. I did put the float in a cup of water and noticed no bubbles. Does this sound like a bad float? I noticed the the idle was about 1400 when the float was high. Can the idle be high with a high float? I did order a new float just in case.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Float problems on 6 pack [Re: 70sixpkrt] #1887896
08/09/15 03:39 AM
08/09/15 03:39 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
IIRC, if you center the float in the bowl with bowl inverted, it will be close. Other than that, it's tough to use the sightglass method if you don't have electric pump. (eng shakes a bit with engine running the mechanical pump etc).
Re: Float problems on 6 pack [Re: 70sixpkrt] #1887897
08/09/15 03:45 AM
08/09/15 03:45 AM
I did that and gas was pouring out so I lowered it a tad and not even a dribble.
4-speed
3:54 Dana
Re: Float problems on 6 pack [Re: 70sixpkrt] #1887905
08/09/15 05:15 AM
08/09/15 05:15 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I've worked on these & the Vette Tri Power
I set the floats with the bowls in my hand,upside down with the float flat & parallel to the top of the bowl
Check your seats as the ethanol enriched gas will groove the rubber & sometimes make it crack
I change them to ones for alcohol use
Re: Float problems on 6 pack [Re: 70sixpkrt] #1887942
08/09/15 11:16 AM
08/09/15 11:16 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The float is nitrophyl,you will see no bubbles and there are very few problems with them,change the needle/seat and center the float !!
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888001
08/09/15 01:11 PM
08/09/15 01:11 PM
I did change the needle/ seat and centered the float inverted. It seemed like a stuck float. The new float is coming today. It's weird. I did not have this problem before I changed the gas tank and sending unit.
4-speed
3:54 Dana
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888011
08/09/15 01:31 PM
08/09/15 01:31 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Do you by any chance have the aftermarket jet plates in your outer carbs? I ran into one that the float would catch on the jets and do what you are seeing.
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888018
08/09/15 01:43 PM
08/09/15 01:43 PM
Yes. I am using the Promax jettable plates for the outboards. I've been using them for the last 8 yrs with no problems.
4-speed
3:54 Dana
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888044
08/09/15 02:19 PM
08/09/15 02:19 PM
debris (common,need a good filter). bad needle/seat (common). float linkage hanging up (possible but less likely)
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888138
08/09/15 05:09 PM
08/09/15 05:09 PM
How can it be debri if it is a new tank and unit? I did notice that the jets were black. I can remove the black with my finger and they turn gold again. Is that from the alcohol that's in the gas now a days?
4-speed
3:54 Dana
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888146
08/09/15 05:21 PM
08/09/15 05:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
New doesn't mean clean
Don't be the exception.
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888356
08/09/15 10:27 PM
08/09/15 10:27 PM
(1) alot of debris gets by the gas stn filters (2) I believe so yes. #1 need a high quality 10 micron filter right before the carb inlet
Re: Float problems on 6 pack [Re: Supercuda] #1888378
08/09/15 10:44 PM
08/09/15 10:44 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
X2
`68 Barracuda 340-S
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888481
08/10/15 12:11 AM
08/10/15 12:11 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've seen guys go back through the carbs and retorque the bowl gaskets...The added compression made the float come in contact with the aftermarket jet plate after years of trouble free service so it does happen... twocents
Re: Float problems on 6 pack [Re: screamindriver] #1888503
08/10/15 12:53 AM
08/10/15 12:53 AM
GomangoCuda Offline
GomangoCuda  Offline
Take a close look at the float and see if it has tiny marks where one or both jets contacted the float.
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888547
08/10/15 01:52 AM
08/10/15 01:52 AM
Thanks for the suggestions. What I did was took apart the rear carb and cleaned it. Replaced the needle/seat and float. Changed gaskets. Set the float inverted. Got it running. Took it for a small ride and came home. I left it running and checked the sight hole. With it running it just trickled out. Right now it's running good. I know in a couple of weeks, I'm going to take off the center carb and do the same thing. I think it was the float hanging up. Crossing my fingers.
4-speed
3:54 Dana
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888554
08/10/15 02:06 AM
08/10/15 02:06 AM
With a good filter I'd say you are good. only prob with doing multiple fixes at the same time is you dont know which one was the culprit but we cant argue with success. I hear properly setup 6 packs are a killer
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888556
08/10/15 02:10 AM
08/10/15 02:10 AM
That's why I'm waiting a couple of weeks to do the center carb.
4-speed
3:54 Dana
Re: Float problems on 6 pack [Re: 70sixpkrt] #1888596
08/10/15 05:02 AM
08/10/15 05:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What fuel pressure? My friends 6-pack was doing the same thing on both end carbs, but not the center carb. I think he had 8 or 9 psi, and the pressure was bending the aluminum flat arms. We noticed the end carbs had the floats with the aluminum arms, and the center carb had the brass float arms and we did not have an issue with the center carb. We lowered the fuel pressure, re-bent the float arms so we could adjust the fuel level (we maxed out the needle/seat adjustment tring to set the float level.)
