Re: Float problems on 6 pack
[Re: 70sixpkrt]
#1888011
08/09/15 01:31 PM
08/09/15 01:31 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Do you by any chance have the aftermarket jet plates in your outer carbs? I ran into one that the float would catch on the jets and do what you are seeing.
[Re: 70sixpkrt]
#1888044
08/09/15 02:19 PM
08/09/15 02:19 PM
RapidRobert
debris (common,need a good filter). bad needle/seat (common). float linkage hanging up (possible but less likely)
[Re: 70sixpkrt]
#1888356
08/09/15 10:27 PM
08/09/15 10:27 PM
RapidRobert
How can it be debri if it is a new tank and unit? I did notice that the jets were black. I can remove the black with my finger and they turn gold again. Is that from the alcohol that's in the gas now a days? (1) alot of debris gets by the gas stn filters (2) I believe so yes. #1 need a high quality 10 micron filter right before the carb inlet
[Re: screamindriver]
#1888503
08/10/15 12:53 AM
08/10/15 12:53 AM
GomangoCuda
Yes. I am using the Promax jettable plates for the outboards. I've been using them for the last 8 yrs with no problems. I've seen guys go back through the carbs and retorque the bowl gaskets...The added compression made the float come in contact with the aftermarket jet plate after years of trouble free service so it does happen... Take a close look at the float and see if it has tiny marks where one or both jets contacted the float.
[Re: 70sixpkrt]
#1888554
08/10/15 02:06 AM
08/10/15 02:06 AM
RapidRobert
With a good filter I'd say you are good. only prob with doing multiple fixes at the same time is you dont know which one was the culprit but we cant argue with success. I hear properly setup 6 packs are a killer
