Just got towed home 73 challenger. #1887801
08/08/15 11:53 PM
08/08/15 11:53 PM
Monee IL
chicagotim2003 Offline OP
Monee IL
I was about 20 miles from home just enjoying a beautiful Saturday night. Car seemed to be running fine. As i was driving i felt a little hick up. About a mile later another one. I pulled into a church and as i did the car died! I have a full tank of gas. I checked the carb and it sprays gas into the carb. Battery is strong and will crank. I`m thinking no spark. I have a extra ecm in the trunk. Put the ecm on and nothing. I have a brand new ballast,put that on nothing. I have a extra coil,put that on nothing. Pull the cap off and the rotor spins when i crank so i guess timing chain is still there. Sun went down and i called for the hook. How do i trouble shoot this? Very frustrated and need a beer !!!!!
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887813
08/09/15 12:04 AM
08/09/15 12:04 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Do you have power to the ballast resistor? Sorry to hear you having troubles. At least you have beer!
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887816
08/09/15 12:05 AM
08/09/15 12:05 AM
Kirkland, Washington
Pacnorthcuda Offline
Check the wire to the coil along the intake...make sure it's not grounding due to heat/melting.
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887823
08/09/15 12:09 AM
08/09/15 12:09 AM
Monee IL
Monee IL
Test light says nothing to the ballast resistor.
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887833
08/09/15 12:42 AM
08/09/15 12:42 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Exactly what happened to my Challenger one week ago. Repo Wiring harness tab at the firewall plug was not crimped properly.
Sheldon
Sheldon
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887843
08/09/15 01:04 AM
08/09/15 01:04 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
As i read this..you didnt check for spark..pull the coil wire at the cap.check that first..
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887850
08/09/15 01:17 AM
08/09/15 01:17 AM
Monee IL
Monee IL
Just checked again i do have power at the ballast and coil. Ill check spark in the morning. Thanks guys!
Re: Just got towed home 73 challenger. [Re: AARCONV] #1887866
08/09/15 01:55 AM
08/09/15 01:55 AM
pull the yellow wire off of the starter relay to disable the starter then with a helper: with key "on" and held to "start" the coil positive primary terminal and the blue/yellow ECU terminal need to be hot (2 key positions/2 terminals= 4 checks) (plus the red/green ECU terminal if an OE 5 pin ECU (OE 5 pin ECU has a functioning 5th pin that is fed by the red/green wire). I'd seperate/clean the bulkhead first
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887972
08/09/15 12:24 PM
08/09/15 12:24 PM
Monee IL
Monee IL
I went out this morning and started poking around with the test light. I was about to try the test rapid robert recommended. For the hell of it i tried to start it and it started and ran very rough. I shut it off and noticed gas seemed to keep dripping in to the carb. I started it again and it was running very rough. I shut it off and again noticed gas still dripping into to the carb. Carb is a holley 750. 3310 model. The car started and ran. I assume electric must be ok for it to run. Am i looking at a fuel problem here? Next move?
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887989
08/09/15 12:53 PM
08/09/15 12:53 PM
central illinois
65dodgebob Offline
65dodgebob  Offline
central illinois
sounds like float issue. possibly float is stuck (needle/seat), or float level is too high. I would check float levels first. other possibility is if idle speed is too high(big cam, rough idle,etc.) carb may be pulling fuel in from main circuit instead of idle circuit. try reducing idle speed.
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1887990
08/09/15 12:55 PM
08/09/15 12:55 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Most likely some debris in one of the carbs needle and seats, I would just replace them both, reset the floats and try it. I assume the carb hasn't been apart for awhile?
Sheldon
Sheldon
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888012
08/09/15 01:32 PM
08/09/15 01:32 PM
Monee IL
Monee IL
Ok just googled some holley carb troubleshooting. I took off rear bowl plug tiny amount of fuel came out. Sprayed carb clean in bowl. Took out needle and sprayed carb clean. Went to the front bowl and took out plug. A ton of fuel came out like a water fall. Did the same carb cleaned bowl and needle.Started up and seems to run smooth. Turned it on and off at least 6 times. Noticed when it was off fuel was not leaking down into carb. This carb has never been apart in the 16 years i`ve owned it. With all the gas in the front bowl will that problem come back?
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888017
08/09/15 01:40 PM
08/09/15 01:40 PM
What Sheldon said, replace the needle/seat assys, set the floats (dry then wet/idleing) & you'll be fine. good filter in front of carb. Wix is good
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888051
08/09/15 02:31 PM
08/09/15 02:31 PM
Monee IL
Monee IL
When i pulled the plug off the front bowl a lot of gas came out. Like it was filled to the top. Would a clogged needle cause that? How would that make my car die after driving for 20 miles?
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888059
08/09/15 02:39 PM
08/09/15 02:39 PM
(1) yes (2) it took that long for the flooding to reach a critical mass bad enough to kill the eng, it can leak some or a lot & it varies
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888623
08/10/15 09:47 AM
08/10/15 09:47 AM
USA
540DUSTER Offline
540DUSTER  Offline
USA
holley carb 16 years old and never had been apart.Time for a rebuild.I bet that carb has all kinds of ethanol crusties in it.
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888965
08/10/15 06:15 PM
08/10/15 06:15 PM
Monee IL
Monee IL
Yes, carb rebuild is my next move. Cleaning the needle on the front bowl seems to have fixed the problem for now. As always thanks for sharing the knowledge!!!! moparts is awesome!!!!!
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1888969
08/10/15 06:19 PM
08/10/15 06:19 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Replace needle/seat and float. This just happened to me 2 days ago.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1889069
08/10/15 09:24 PM
08/10/15 09:24 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What happened to no power to the ballast resister?
Re: Just got towed home 73 challenger. [Re: chicagotim2003] #1889650
08/11/15 06:31 PM
08/11/15 06:31 PM
Monee IL
Monee IL
When i checked the ballast i think i did not have the key turned forward. I was frustrated smile
