Opinions on shifter options for Reverse Manual Valve Body? #1887577
08/08/15 06:05 PM
08/08/15 06:05 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Looking for a shifter for my BB 727 in my Street/strip car. Im looking at the Hurst quarter stick, the B&M Pro ratchet and the Cheetah SCS.
I've used B&M before with good results, and have heard many times that the Pro Ratchet is the 'go to' shifter for RMVB and doesnt miss a shift ever when set up properly.
I like the looks of the Hurst and the model Im looking at has a button on top which is very handy, but I've heard people missing shifts when using it aggressively.
I've never seen or heard much of the cheetah, but supposedly its an excellent shifter. I like the look of it too.
What do you guys with reverse manual valve bodies use? Any opinions about the shifters I'm looking at?
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1887580
08/08/15 06:13 PM
08/08/15 06:13 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I am happy with my pro stick.. the pro ratchet is different..in my pro stick I cant mess up a shift, first pull into second is just a pull, last shift you have to pull the trigger...coming to a stop you can just push the shifter all the way to 1st...the only thing about this shifter is the cable is in the front of the shifter..
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1887586
08/08/15 06:28 PM
08/08/15 06:28 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
I like the pro-ratchet, I've used it in a few different cars.
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: AARCONV] #1887594
08/08/15 06:55 PM
08/08/15 06:55 PM
Can the pro stick be used with a reverse pattern VB?
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1887596
08/08/15 07:03 PM
08/08/15 07:03 PM
MN
W
Willie68coronet Offline
W
MN
I bought a second hand brand new b&m megashifter for about a $100 a few years ago and just installed it this last year with my rebuilt 727 with a cope reverse valve body. I'm loving it so far. Just had to get a separate reverse pattern indicator window instead of the forward.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888107
08/09/15 04:01 PM
08/09/15 04:01 PM
Anyone here using the cheetah?
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888108
08/09/15 04:07 PM
08/09/15 04:07 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
All the Mopar racers I know in Arizona use the T/A and really like it. Most of the stock eliminator Mopars use it too. I really like mine.
Raul
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888110
08/09/15 04:08 PM
08/09/15 04:08 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
I had a pro-matic 2 which has the front feed cable that got quickly melted from the headers in about 1/2 hour. Something to consider when choosing.
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888112
08/09/15 04:14 PM
08/09/15 04:14 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Had an old B&M Quick Click years ago, bought it new, ratchet style shifter for my drag car. Ratchet mechanism broke while in the water box, cost me a run in the semi finals. Never again will I use a ratchet shifter. Bought the B&M equivalent of the hurst quarter stick. It has interchangeable gates for forward or reverse valve bodies - you buy the gate you need. I'll only use a gated after market auto trans shifter from now on - my twocents, my experience...
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888466
08/09/15 11:49 PM
08/09/15 11:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes as I use the B&M Pro Stick with my Turbo Action RMVB. I really like the Pro Stick as its easy to use and works great when racing for me. And its not a ton of money. Ron
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888470
08/09/15 11:55 PM
08/09/15 11:55 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I have a cheetah in my current car and also had one in my 67.. Never any issues in either one.Kevin
71 gtx.....
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888716
08/10/15 12:45 PM
08/10/15 12:45 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I've had my TA shifter in my Cuda since 88 or 89 no issues. Just removed it from the Cuda and put it in my Belvedere.
Ok
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: sleddinfool] #1888747
08/10/15 01:30 PM
08/10/15 01:30 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I also used a B&M Quick Click in my old race car and because of the cable routing I had issues with header heat and cable destruction. I now have a Cheetah for the new racer and the cable comes out the back of the shifter and comes at the trans from the rear...no more issue!!
Personally I would not bother with a RMVB on a street car or even a street/strip car. I found out from Al Young (many time NW drag champion) that all the times we raced he used an auto valve body with custom governor weights from Pat Blais that shifted itself and his shifter was mostly for show. Al's Bardahl Challenger is in the Seattle Museum of History & Industry and on display frequently
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888751
08/10/15 01:38 PM
08/10/15 01:38 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I had a B&M Quick Silver and replaced it with a Cheetah SCS. Had nothing but problems with the B&M.
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1888964
08/10/15 06:14 PM
08/10/15 06:14 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Turbo Action's Cheetah...I just bought one and I really like it!
Nautilus Racing-
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: 383man] #1890050
08/12/15 02:28 AM
08/12/15 02:28 AM
Ron does the pro stick get cumbersome on the street?
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1890192
08/12/15 12:10 PM
08/12/15 12:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not to me at all as its easy to use and drive with. And you can go into reverse using just one hand. It has the little lever you push to go in reverse and you can push it with your right hand as I do and then just push the shifter into reverse with the same hand. You dont have to hold the revere lever when going in reverse as you just push it and then let it go and then use the same hand and put the shifter in reverse. I think some think you need two hands to go into reverse when they see the extra lever but you do not. Ron
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Adam71Charger] #1890931
08/13/15 12:30 PM
08/13/15 12:30 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
And the pro stick cover is aluminum. .you can polish it or have it Chromed like I did
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: Polarapete] #1891010
08/13/15 02:13 PM
08/13/15 02:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
What model cheetah shifter for a Mopar comes with rear exit? Turbo action shows them leaving the front of the shifter, bending around in a circle and approaching the trans from the rear. They show the Chevy and Ford shifters as having rear exit. Perhaps you have a Glide in your race car? http://www.turboaction.com/shifter2.html
Oh, by the way I notice that racecar spelled backwards spells racecar.
Re: Opinions on shifter options for Reverse Manual Valve Body? [Re: GomangoCuda] #1891862
08/14/15 02:54 PM
08/14/15 02:54 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Cheetah, I love it!
