Re: Opinions on shifter options for Reverse Manual Valve Body?
[Re: Adam71Charger]
#1887580
08/08/15 06:13 PM
08/08/15 06:13 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
I am happy with my pro stick.. the pro ratchet is different..in my pro stick I cant mess up a shift, first pull into second is just a pull, last shift you have to pull the trigger...coming to a stop you can just push the shifter all the way to 1st...the only thing about this shifter is the cable is in the front of the shifter..
[Re: AARCONV]
#1887594
08/08/15 06:55 PM
08/08/15 06:55 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I am happy with my pro stick.. the pro ratchet is different..in my pro stick I cant mess up a shift, first pull into second is just a pull, last shift you have to pull the trigger...coming to a stop you can just push the shifter all the way to 1st...the only thing about this shifter is the cable is in the front of the shifter.. Can the pro stick be used with a reverse pattern VB?
[Re: Adam71Charger]
#1887596
08/08/15 07:03 PM
08/08/15 07:03 PM
Posts: 277 MN
Willie68coronet
MN
I bought a second hand brand new b&m megashifter for about a $100 a few years ago and just installed it this last year with my rebuilt 727 with a cope reverse valve body. I'm loving it so far. Just had to get a separate reverse pattern indicator window instead of the forward.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Adam71Charger]
#1888112
08/09/15 04:14 PM
08/09/15 04:14 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Had an old B&M Quick Click years ago, bought it new, ratchet style shifter for my drag car. Ratchet mechanism broke while in the water box, cost me a run in the semi finals. Never again will I use a ratchet shifter. Bought the B&M equivalent of the hurst quarter stick. It has interchangeable gates for forward or reverse valve bodies - you buy the gate you need. I'll only use a gated after market auto trans shifter from now on - my , my experience...
[Re: Adam71Charger]
#1888466
08/09/15 11:49 PM
08/09/15 11:49 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I am happy with my pro stick.. the pro ratchet is different..in my pro stick I cant mess up a shift, first pull into second is just a pull, last shift you have to pull the trigger...coming to a stop you can just push the shifter all the way to 1st...the only thing about this shifter is the cable is in the front of the shifter.. Can the pro stick be used with a reverse pattern VB? Yes as I use the B&M Pro Stick with my Turbo Action RMVB. I really like the Pro Stick as its easy to use and works great when racing for me. And its not a ton of money. Ron
[Re: Adam71Charger]
#1888470
08/09/15 11:55 PM
08/09/15 11:55 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I have a cheetah in my current car and also had one in my 67.. Never any issues in either one.Kevin
71 gtx.....
[Re: Adam71Charger]
#1888716
08/10/15 12:45 PM
08/10/15 12:45 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I've had my TA shifter in my Cuda since 88 or 89 no issues. Just removed it from the Cuda and put it in my Belvedere.
Ok
[Re: sleddinfool]
#1888747
08/10/15 01:30 PM
08/10/15 01:30 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I also used a B&M Quick Click in my old race car and because of the cable routing I had issues with header heat and cable destruction. I now have a Cheetah for the new racer and the cable comes out the back of the shifter and comes at the trans from the rear...no more issue!! Personally I would not bother with a RMVB on a street car or even a street/strip car. I found out from Al Young (many time NW drag champion) that all the times we raced he used an auto valve body with custom governor weights from Pat Blais that shifted itself and his shifter was mostly for show. Al's Bardahl Challenger is in the Seattle Museum of History & Industry and on display frequently
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Adam71Charger]
#1888751
08/10/15 01:38 PM
08/10/15 01:38 PM
Posts: 1,377 Ohio
Todd
Ohio
I had a B&M Quick Silver and replaced it with a Cheetah SCS. Had nothing but problems with the B&M.
[Re: Adam71Charger]
#1888964
08/10/15 06:14 PM
08/10/15 06:14 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Turbo Action's Cheetah...I just bought one and I really like it!
[Re: 383man]
#1890050
08/12/15 02:28 AM
08/12/15 02:28 AM
Adam71Charger
I am happy with my pro stick.. the pro ratchet is different..in my pro stick I cant mess up a shift, first pull into second is just a pull, last shift you have to pull the trigger...coming to a stop you can just push the shifter all the way to 1st...the only thing about this shifter is the cable is in the front of the shifter.. Can the pro stick be used with a reverse pattern VB? Yes as I use the B&M Pro Stick with my Turbo Action RMVB. I really like the Pro Stick as its easy to use and works great when racing for me. And its not a ton of money. Ron Ron does the pro stick get cumbersome on the street?
[Re: Adam71Charger]
#1890192
08/12/15 12:10 PM
08/12/15 12:10 PM
383man
Balt. Md
I am happy with my pro stick.. the pro ratchet is different..in my pro stick I cant mess up a shift, first pull into second is just a pull, last shift you have to pull the trigger...coming to a stop you can just push the shifter all the way to 1st...the only thing about this shifter is the cable is in the front of the shifter.. Can the pro stick be used with a reverse pattern VB? Yes as I use the B&M Pro Stick with my Turbo Action RMVB. I really like the Pro Stick as its easy to use and works great when racing for me. And its not a ton of money. Ron Ron does the pro stick get cumbersome on the street? Not to me at all as its easy to use and drive with. And you can go into reverse using just one hand. It has the little lever you push to go in reverse and you can push it with your right hand as I do and then just push the shifter into reverse with the same hand. You dont have to hold the revere lever when going in reverse as you just push it and then let it go and then use the same hand and put the shifter in reverse. I think some think you need two hands to go into reverse when they see the extra lever but you do not. Ron
[Re: Polarapete]
#1891010
08/13/15 02:13 PM
08/13/15 02:13 PM
Posts: 4,727 Moved to N.E. Tennessee
GomangoCuda
I also used a B&M Quick Click in my old race car and because of the cable routing I had issues with header heat and cable destruction. I now have a Cheetah for the new racer and the cable comes out the back of the shifter and comes at the trans from the rear...no more issue!! What model cheetah shifter for a Mopar comes with rear exit? Turbo action shows them leaving the front of the shifter, bending around in a circle and approaching the trans from the rear. They show the Chevy and Ford shifters as having rear exit. Perhaps you have a Glide in your race car? http://www.turboaction.com/shifter2.html Oh, by the way I notice that racecar spelled backwards spells racecar.
