is this a original SHAKER bubble? #188697
01/09/09 06:34 PM
01/09/09 06:34 PM
Anonymous OP
Anonymous OP
from this photo can you tell me if this is a factory original shaker bubble?
from the picture i cant see the stamped pentastar. thanks
Re: is this a original SHAKER bubble? #188698
01/09/09 07:21 PM
01/09/09 07:21 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Seeing the stamped pentastar is not a sure way to tell if it is a real shaker scoop.
Several repros carry the pentastar, part number and vendor number just like originals.
The only real way to tell is by defining the composite material it is made of.
The repros have not perfected that yet.
Re: is this a original SHAKER bubble? [Re: mccannix] #188699
01/09/09 07:23 PM
01/09/09 07:23 PM
Anonymous OP
Anonymous OP
TERRY,does it look like a original from the picture?
Re: is this a original SHAKER bubble? #188700
01/09/09 07:36 PM
01/09/09 07:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Chris,
Trust me on this one, it APPEARS original, but as Terry said, until you determine what it's made of (the originals were made of a unique composite material that to date no reproduction is made from) you won't be able to know for sure from just that picture.
Re: is this a original SHAKER bubble? #188701
01/09/09 09:30 PM
01/09/09 09:30 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
it looks orig from what i can see
check some of the wear iteams like around the 7 holes that bolts bubble down to adapter ring for small cracks and also check and see how well orig air grills fit compared to repops around the boss that hold the air door vent as well it appears to have 4406 bages the way the hole pattern is forward on one side
im not the expert so dont go forward on what i say i just speak from mt expierence from repop and orig bubbles as i have both
if it dont know have the numbers i would say no
scott the man on shakers listen to him
Re: is this a original SHAKER bubble? #188702
01/09/09 09:35 PM
01/09/09 09:35 PM
Anonymous OP
Anonymous OP
is this on your challenger
Re: is this a original SHAKER bubble? #188703
01/09/09 09:40 PM
01/09/09 09:40 PM
Anonymous OP
Anonymous OP
no Tom, im loking at a 70 cuda 440-6 4 speed.car looks nice from photos, i found a couple of things that need attention, but the restoration looks nice.
before i fly in to see it, i want to make sure it has original parts on it.
Re: is this a original SHAKER bubble? #188704
01/09/09 10:03 PM
01/09/09 10:03 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
This is suppose to be an NOS bubble and I don't doubt that it is, but I can't remember were I got the picture. So take it for what it is worth.
Re: is this a original SHAKER bubble? #188705
01/09/09 10:04 PM
01/09/09 10:04 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I agree with Scott, it APPEARS to be real.
A couple things to consider when visually checking real verses repro.
On most repros I have seen, the drain openings on each side seem a little more "puffy" or thicker than on an orignal.
As for the emblems, all factory scoops have the 3 prong nameplate holes in the same location, be it 340, 383, 440, or hemi.
This one must have the steel hood 440-6 nameplates as evident by the two prongs poking through instead of mandatory 3 prongs for shaker nameplates.
Hard to tell but some of the mounting grills/doors harware does not look original, but overall it looks like a real nice unit.
Re: is this a original SHAKER bubble? [Re: mccannix] #188706
01/09/09 10:13 PM
01/09/09 10:13 PM
Snoopy Offline
Snoopy  Offline
Terry, I lightened up the picture a bit and it looks like there are 3 holes on each side for the emblems.
Re: is this a original SHAKER bubble? [Re: Snoopy] #188707
01/09/09 11:03 PM
01/09/09 11:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Snoop,
I think what Terry was describing was the fact that all original Shaker emblems had 3 prongs rather than two, so it's apparent that the emblems themselves are reproductions or are missing one pin due to damage. The holes appear correct, but they also appear correct on some of the better reproduction bubbles. One thing I think looks incorrect is the color of the material, originals are not a true white, they have a yellowish cast to them plus it's normally a bit uneven and mottled, it's pretty much impossible to duplicate with paint of any shade. The bubble looks too even so it's likely been completely painted and then over sprayed to make it appear more original, again, hard to say as pictures and lighting can be decieving. As Terry said, if it's a reproduction it's a nicely detailed one, beyond that, can't say from just that pic.
*Pic is an original Paint 71 bubble, a very nice original condition. Good for comparisons
Re: is this a original SHAKER bubble? [Re: ScottSmith_Harms] #188708
01/09/09 11:12 PM
01/09/09 11:12 PM
Snoopy Offline
Snoopy  Offline
Scott,
Your right, I read over the emblem statement.
Re: is this a original SHAKER bubble? #188709
01/09/09 11:19 PM
01/09/09 11:19 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
FWIW, it looks original to me. We have an original 70 440-6 in the shop now. The underside of that car's bubble looks like what you have pictured. I've had to re-work way too many reproductions , and none were as defined around the perimeter with centered bolt holes or had the raised bosses centered with the screws. All the repro's I've dealt with had to have the bosses reglassed to shift or raise them in order for the screwed on components to fit decent. And I won't begin to describe the problems with the top sides
of the repro's.
Re: is this a original SHAKER bubble? [Re: mccannix] #188710
01/10/09 12:02 AM
01/10/09 12:02 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
FWIW....You can buy my 1971 440+6 Cuda...It has an original bubble
Re: is this a original SHAKER bubble? [Re: anlauto] #188711
01/10/09 07:17 AM
01/10/09 07:17 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Chris,
Here you go
Bob
Re: is this a original SHAKER bubble? [Re: Snoopy] #188712
01/10/09 09:14 AM
01/10/09 09:14 AM
Anonymous OP
Anonymous OP
thanks guys, does that fresh air door look real?
its hard to tell from the picture.
Re: is this a original SHAKER bubble? #188713
01/10/09 09:53 AM
01/10/09 09:53 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Chris, if I were guessing I would think the warm door looks like a repro.
Here's a shot of an NOS one and as you can see the area where the baffle closes flush against has a more rounded feature than the one in your photo.
Re: is this a original SHAKER bubble? [Re: mccannix] #188714
01/10/09 09:55 AM
01/10/09 09:55 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Here's a closer shot of what I am talking about.
Two of the repro door vendors dont have it quite like this.
Its easy to compare with the picture that Snoopy lightened.
Re: is this a original SHAKER bubble? [Re: mccannix] #188715
01/10/09 10:33 AM
01/10/09 10:33 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
One more with part #
Re: is this a original SHAKER bubble? #188716
01/10/09 11:06 AM
01/10/09 11:06 AM
MD
floyd Offline
floyd  Offline
MD
Here are a couple of one I have
