Re: drag car shifter
[Re: LimeRT]
#1886694
08/07/15 12:20 AM
08/07/15 12:20 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
after also asking in forum , see is there a better shifter , the best appears to be the PPP shifter then a close choice between B&M proratchet and Cheetah SCS (Turbo action) and so on down the line
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: LimeRT]
#1886780
08/07/15 03:59 AM
08/07/15 03:59 AM
Posts: 43,178 Bend,OR USA
Cab_Burge
Are you going to shift it or is a box or some other device going to make the shift? If your going to shift it I like and use the older Fairbanks, Winters ,AKA Turbo action shifters If the box is then one like the one showed Mine, shiftnoid, is air shifted in S/P car based off of RPM out of the Biondo 400 box
[Re: J_BODY]
#1887052
08/07/15 07:01 PM
08/07/15 07:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I love the Pro Ratchet... has NEVER missed a shift and if you were to need a part... Summit... I've had it in the car for 14 years now
[Re: LimeRT]
#1887062
08/07/15 07:20 PM
08/07/15 07:20 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am also running a Pro Ratchet and it works great.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: LimeRT]
#1887065
08/07/15 07:21 PM
08/07/15 07:21 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I just switched from Hurst Auto stick 3 to Turbo Action and the TA shifter is great.
