Aluminum fuel tanks and fuel lines
#1885967
08/05/15 11:13 PM
08/05/15 11:13 PM
Posts: 7,506 Az
Crizila
Az
Will they survive todays fuels?
Fastest 300
Re: Aluminum fuel tanks and fuel lines
[Re: Crizila]
#1885978
08/05/15 11:27 PM
08/05/15 11:27 PM
moparpollack
Lil Herman
Lil Herman
85086
I wouldn't just because car manufactures never did. Aluminum works good on race cars that don't get used for long periods of time. But I have a plastic tank and wish I had a steel tank.
[Re: OzHemi]
#1886550
08/06/15 09:53 PM
08/06/15 09:53 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Wow that looks really nice. Makes a Pinto look safe though. Really hangin' out there ain't it?
I have mechanical Aptitude. I can screw up anything.
[Re: Crizila]
#1886719
08/07/15 12:47 AM
08/07/15 12:47 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Yep, but been used on the roads/street cars in Oz since the 70's when the cars were racing and people started using them as well. When you have a 1000 kilometer road race, the bigger the tank the better. And a lot of people ran them on the street as well after that and currently. (Does make setting up the suspension a little more interesting with the amount of weight as a variable.) Mine is 110 liters by the way...
[Re: ]
#1886823
08/07/15 11:40 AM
08/07/15 11:40 AM
Posts: 7,506 Az
Crizila
Az
Mine aint hanging quite that low. Then again it's only 13 gals. Went with plastic on my race car.
Fastest 300
[Re: Crizila]
#1886949
08/07/15 03:54 PM
08/07/15 03:54 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My friend's '33 Willys project.
[Re: ]
#1886990
08/07/15 05:15 PM
08/07/15 05:15 PM
OzHemi
Garden Grove, CA
The good ol' Aussie "drop tank" Must get a few strange looks on the roads over there mate. Nice Torrie! Thanks! And yep, gets lots of looks...even after all the years I have had it here. (Street Machine did a write up on it actually even which was cool I thought)
[Re: Crizila]
#1887375
08/08/15 11:07 AM
08/08/15 11:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Will they survive todays fuels? Yes they will live... unless your using methanol.. ethanol is no problem... I built this one for my hot rod..18 gal
[Re: ]
#1889003
08/10/15 07:11 PM
08/10/15 07:11 PM
Posts: 349 West Central Wisconsin
DeMopuar
Don't you have to use a dedicated type of rubber hose for E85? (for the flexible & joiner parts in your fuel lines)
Just use fuel injection rubber fuel lines. These rubber lines are engineered to run all of the common fuels of today at the pump.
