Aluminum fuel tanks and fuel lines #1885967
08/05/15 11:13 PM
08/05/15 11:13 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Will they survive todays fuels?
Fastest 300
Re: Aluminum fuel tanks and fuel lines [Re: Crizila] #1885978
08/05/15 11:27 PM
08/05/15 11:27 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I wouldn't just because car manufactures never did. Aluminum works good on race cars that don't get used for long periods of time. But I have a plastic tank and wish I had a steel tank.
Re: Aluminum fuel tanks and fuel lines [Re: moparpollack] #1886003
08/05/15 11:54 PM
08/05/15 11:54 PM
moparx Offline
moparx  Offline
if a guy were to build one, i think i would go stainless. it's easier to weld than aluminum [ at least for me] and way better than bare steel. just my opinion.
beer
Re: Aluminum fuel tanks and fuel lines [Re: moparx] #1886079
08/06/15 01:51 AM
08/06/15 01:51 AM
Oh
His and Her 69's Offline
Oh
Yes the aluminum will be fine with todays fuels. Even works Good with E-85 fuel in them. Me and a bunch of friends run them and never any issues with the tanks. We run 93 octane now, ran airplane fuel prior to that. My other car ran 110 race gas then E-85 and no Problems.
We street drive the blue RR a lot on 93.
When I do my 36 Ply coupe I will have an aluminum tank in it.
David
Re: Aluminum fuel tanks and fuel lines [Re: moparpollack] #1886165
08/06/15 10:40 AM
08/06/15 10:40 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Plastic tanks are actually safer....better in crashes and better in fires.
Re: Aluminum fuel tanks and fuel lines [Re: Crizila] #1886330
08/06/15 04:08 PM
08/06/15 04:08 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
aluminum tanks get used in boats all the time---i have saved several from boat partouts for hot rod applications....
Re: Aluminum fuel tanks and fuel lines [Re: Crizila] #1886462
08/06/15 08:05 PM
08/06/15 08:05 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have an aluminum drop tank in my Holden Torana...very popular and common in Oz, and have no troubles with it at all. (they were used in race cars to gain capacity (all long road race cars) and carried over to street cars and are seen often on this era/style of car still.
Re: Aluminum fuel tanks and fuel lines [Re: OzHemi] #1886550
08/06/15 09:53 PM
08/06/15 09:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Wow that looks really nice.
Makes a Pinto look safe though. eek
Really hangin' out there ain't it?
I have mechanical Aptitude.
I can screw up anything.
Re: Aluminum fuel tanks and fuel lines [Re: Crizila] #1886719
08/07/15 12:47 AM
08/07/15 12:47 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Yep, but been used on the roads/street cars in Oz since the 70's when the cars were racing and people started using them as well. When you have a 1000 kilometer road race, the bigger the tank the better. laugh And a lot of people ran them on the street as well after that and currently. (Does make setting up the suspension a little more interesting with the amount of weight as a variable.)
Mine is 110 liters by the way...
Re: Aluminum fuel tanks and fuel lines [Re: ] #1886823
08/07/15 11:40 AM
08/07/15 11:40 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Mine aint hanging quite that low. Then again it's only 13 gals. Went with plastic on my race car.
Fastest 300
Re: Aluminum fuel tanks and fuel lines [Re: Crizila] #1886949
08/07/15 03:54 PM
08/07/15 03:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My friend's '33 Willys project.
Re: Aluminum fuel tanks and fuel lines [Re: ] #1886990
08/07/15 05:15 PM
08/07/15 05:15 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Originally Posted By Mudgy
The good ol' Aussie "drop tank"
Must get a few strange looks on the roads over there mate.
Nice Torrie!
Thanks! up
And yep, gets lots of looks...even after all the years I have had it here.
(Street Machine did a write up on it actually even which was cool I thought)
Re: Aluminum fuel tanks and fuel lines [Re: Crizila] #1887375
08/08/15 11:07 AM
08/08/15 11:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they will live... unless your using methanol.. ethanol
is no problem... I built this one for my hot rod..18 gal
wave
Re: Aluminum fuel tanks and fuel lines [Re: ] #1889003
08/10/15 07:11 PM
08/10/15 07:11 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
Don't you have to use a dedicated type of rubber hose for E85? (for the flexible & joiner parts in your fuel lines)
Just use fuel injection rubber fuel lines. These rubber lines are engineered to run all of the common fuels of today at the pump.
Re: Aluminum fuel tanks and fuel lines [Re: moparx] #1896626
08/21/15 04:34 PM
08/21/15 04:34 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
beer
A guy i know takes old cheap stainless kitchen sinks cut them in two then welds back together to form his hot rod tanks---got a sending unit hole and one hole to fill where the fuel pickup rests
Re: Aluminum fuel tanks and fuel lines [Re: savoy64] #1898409
08/24/15 03:59 PM
08/24/15 03:59 PM
dogdays Offline
dogdays  Offline
Cheap is good, but ugly kills the thrill.
R.
Re: Aluminum fuel tanks and fuel lines [Re: dogdays] #1898719
08/24/15 11:37 PM
08/24/15 11:37 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
just dont put it in the right front seat like ole Fireball Roberts....
