Correct 11" flywheel #1884454
08/03/15 05:10 PM
08/03/15 05:10 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Good afternoon! I'm switching my '70 Challenger 440 RB from the factory 4 speed to a Tremec 5 speed set-up. Currently I have a 10 1/2" clutch set-up, but the 5 speed takes an 11" clutch. So, my question is, is this the correct flywheel: RAM 1595, 143 tooth, internal balance. I assume the starter position is the same? Sorry for the dumb questions, just kind of confused! Take care!
Re: Correct 11" flywheel [Re: 1969RR] #1884464
08/03/15 05:27 PM
08/03/15 05:27 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
10 1/2" and 11" flywheels are different. 10 1/2" is 130 tooth and 11" is 143 tooth starters. to go to an 11" from a 10 1/2" you need an 11" bellhousing and a 143 tooth starter. the 11" flywheel won't work in a 10 1/2" bell.
Re: Correct 11" flywheel [Re: joelson6] #1884482
08/03/15 05:57 PM
08/03/15 05:57 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey there! Thanks for the reply. I should of stated, I do have the larger bell housing (it came with the 5 speed kit), so I should be good there. I did not know there was / is a different starter tho. I have a smaller, gear-reduction style starter now. Will it not work? It's hard to picture in my mind, but I would think the 143 tooth flywheel would be a larger diameter. Thanks again!
Re: Correct 11" flywheel [Re: 1969RR] #1884495
08/03/15 06:23 PM
08/03/15 06:23 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey there! Got it figured out. SST is going to send me a 10 1/2" clutch set-up. So, problem solved! Thanks for the help! Jeff
Re: Correct 11" flywheel [Re: 1969RR] #1884502
08/03/15 06:39 PM
08/03/15 06:39 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
cool!
Re: Correct 11" flywheel [Re: 1969RR] #1885028
08/04/15 04:11 PM
08/04/15 04:11 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Be aware that an original '70 440 HP is externally balanced/
Re: Correct 11" flywheel [Re: John_Kunkel] #1885598
08/05/15 02:04 PM
08/05/15 02:04 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey John, This is not the original 440. It is one I build couple years ago. Thanks!! Jeff
Re: Correct 11" flywheel [Re: 1969RR] #1885941
08/05/15 10:31 PM
08/05/15 10:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The flywheel size is bellhousing dependent, the size of the clutch is dependent on the pattern on the flywheel.
That said a 10.5 clutch pattern will accept a 10.95 SCALLOPED pattern Pressure plate which is basically an 11.0 clutch.
The smart thing to do , as it seems you finally did , was to contact the company you got the trans setup from and find out what you need.
Re: Correct 11" flywheel [Re: joelson6] #1885942
08/05/15 10:34 PM
08/05/15 10:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Incorrect, there is no such thing as a 143 tooth starter. Chrysler had one basic starter design that fit everything from a /6 to a 440 6 pack and 70/71 Hemi, stick or automatic.
The starter is located by the bellhousing, the only flywheel/bellhousing combo that has a specific starter was used on the 172 tooth HEMI setup prior to 1970.
Re: Correct 11" flywheel [Re: 1969RR] #1886298
08/06/15 03:12 PM
08/06/15 03:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dang I agree with John again.The board is going to blow up.As John said no starter for 130 and 143 wheels.Early hemis and real early cars had specific starters But the 130 143 are the same.Rocky
Chrysler Firepower
Re: Correct 11" flywheel [Re: therocks] #1892990
08/16/15 03:21 PM
08/16/15 03:21 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The real problem is that the larger bellhousing moves the starter into the exhaust manifold/header area. Stock starter fits, but the manifold will not bolt on afterward.
That is why the factory used the direct drive starter with no solenoid sticking out.
Currently some mini starters will fit.
