power master 9523 vs robbmc? #1882823
08/01/15 12:56 PM
08/01/15 12:56 PM
Tacoma, Washington USA
Adam71Charger Offline OP
I'm looking at clockable mini starters. The power master and the robbmc are the same price. The robbmc is smaller and I was about to buy it until I saw the warranty is only 90 days. Has anyone had any problems with either? If you picked one over the other, what was your reason? Is there other options for clockable mini starters?
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1883118
08/01/15 10:10 PM
08/01/15 10:10 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
I think MSD has one.
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1883120
08/01/15 10:12 PM
08/01/15 10:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have installed the RobbMc unit on a project and I was very impressed with the quality of the unit. If I ever needed a clockable starter that would be my first choice twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1883133
08/01/15 10:28 PM
08/01/15 10:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have a clockable PowerMaster on a 440/6 in my Charger, ZERO issues going on 11 years...either starter is a quality unit
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1883199
08/02/15 12:13 AM
08/02/15 12:13 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I have a Powermaster 9523 that I had an issue with. The customer service was the best of any company I've ever dealt with.
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1883467
08/02/15 12:37 PM
08/02/15 12:37 PM
good info on both thanks.
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1883605
08/02/15 04:31 PM
08/02/15 04:31 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I used the Power master 9523 on my engine. Member Dayclona recommended it to me. The wire studs are close on my world block but do clear. The clockable feature really did nothing for my application. One position put it into the block and another position put it into the tti headers. So I used it in the original position it came out of the box in. The starter has been great so far it spins my 528 Hemi over like nothing.
Re: power master 9523 vs robbmc? [Re: HEMIDOG 70] #1884582
08/03/15 08:50 PM
08/03/15 08:50 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I just installed a RobbMc starter on my Barracuda 400 B engine. So far it starts fine and fits well with my 1-3/4" TTI full length headers. The only downsides are 1) the grinding of the block that is required with the new design (B/RB engines) and 2) having to install a relay for the start circuit. If you are using the OE starter, you have to install a diode- that is included with the starter. HTH, Steve
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1884860
08/04/15 10:20 AM
08/04/15 10:20 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
You have to grind the block to fit the RobbMc on a 440?
Re: power master 9523 vs robbmc? [Re: 70VcodeCoronetRT] #1885144
08/04/15 07:43 PM
08/04/15 07:43 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The newest version, yes.
Re: power master 9523 vs robbmc? [Re: Adam71Charger] #1885521
08/05/15 12:12 PM
08/05/15 12:12 PM
Nebraska
Nebraska
Re: power master 9523 vs robbmc? [Re: Skeptic] #1886118
08/06/15 04:40 AM
08/06/15 04:40 AM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
1. When using a 143 tooth ring gear, no grinding is required. When using a 130 tooth ring gear, we have found that grinding on the block is required about 50% of the time. More often on B blocks than RB blocks. It is very close and it depends on the casting shift when the block was machined.
2. The diode that comes with the starter is not required as long as the starter is wired just like stock. If a Ford style relay ("remote solenoid") has been added, the diode may be needed, but probably not.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
