Re: Please recommend a mini starter.. [Re: therocks] #1877627
07/25/15 12:59 AM
07/25/15 12:59 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Paid $150 for a 'high torque mini starter' from a Mopar friendly mail order speed shop. What I got looked identical to the starter that was on my v6 Dakota, same as my v8 Dakota.
You can get those cheap at any parts stores with a core exchange any day of the week.
I've also learned that speed shops have bills to pay and will charge what people are willing to pay.
$200 adjustable roller rockers for magnum heads? Identical to $95 Chevy adjustable roller rockers on eBay. Even arrived in the same packaging.
**Photobucket sucks**
Re: Please recommend a mini starter.. [Re: 70Cuda383] #1877684
07/25/15 02:46 AM
07/25/15 02:46 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Ok thank you for the advice!! up
Re: Please recommend a mini starter.. [Re: MidPenMopar] #1877691
07/25/15 03:03 AM
07/25/15 03:03 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
A starter has a 'service life', Stu...
Spend the money and buy a new one...
Especially if you gots to wrangle it around some TTI's...
Re: Please recommend a mini starter.. [Re: RSNOMO] #1877731
07/25/15 10:01 AM
07/25/15 10:01 AM
I agree and have no problem buying a new one, just want to make sure its very well made and reliable.
Re: Please recommend a mini starter.. [Re: MidPenMopar] #1877773
07/25/15 11:33 AM
07/25/15 11:33 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have always used the Dakota starters and have never had a failure. A while back there was thread about starters and the starter for the '05 2500 5.7 5 speed Ram was the starter of choice. But I can't remember why. Anyway it's part number is P56029274AA and it wasn't very expensive. I can't find that thread right now.
Master, again and still
Re: Please recommend a mini starter.. [Re: MidPenMopar] #1877955
07/25/15 06:01 PM
07/25/15 06:01 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Stu you can save quite a bit of money by hitting up your local Pick N Pull and grab a 1990 and up starter from any Dodge truck. Most you will spend is 15.00 - 20.00 and they are still very serviceable as is. As for your header removal? Yep for the old starter if it is like the stock ones, you will have to remove the left side or more correctly loosen it so it is out of the way and then take the old one out. Put the header back as the mini's are a breeze to remove and install with TTI's in place. I have been running them in all my vehicles as well as my Brother with no issues. Buying new is good but really you don't need to be spending the kinds of money some on here have. Especially when so many are available in the Pick N Pulls...twocentscr8crshr/Bill
Re: Please recommend a mini starter.. [Re: MidPenMopar] #1878185
07/26/15 12:41 AM
07/26/15 12:41 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i drive a v6 Dakota with the mini starter,at one time my buddy had a full size 3/4 360 engine truck that used what we thought was the same starter,we put them side by side and the 360 was just a little longer and bigger around,not by a lot but enough that it showed when side by side
my ladder of success is missing some rungs
Re: Please recommend a mini starter.. [Re: MidPenMopar] #1878393
07/26/15 01:33 PM
07/26/15 01:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Look at the ratings.The 360 starter is higher rated.The V6 is the smallest.With 2 inch TTIs and scatter shield Ill always use a reman or new savin a few bucks isnt that important.Rocky
Chrysler Firepower
Re: Please recommend a mini starter.. [Re: therocks] #1878421
07/26/15 02:16 PM
07/26/15 02:16 PM
Here is the one i am looking at getting/ Pretty much middle of the road pricing and its adjustable fit too.
http://www.summitracing.com/parts/pwm-9513
Re: Please recommend a mini starter.. [Re: rhad] #1878426
07/26/15 02:27 PM
07/26/15 02:27 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Same with the original 440 vs 383 starters ( OEM mopar)
Re: Please recommend a mini starter.. [Re: MidPenMopar] #1878464
07/26/15 03:11 PM
07/26/15 03:11 PM
P
Porter67 Offline
Porter67  Offline
P
Ive used powermaser XS units for a good while on 3 cars and have had zero issues. Not much more then others and never have gotten weak or heat soaked.
Re: Please recommend a mini starter.. [Re: Porter67] #1878979
07/27/15 10:38 AM
07/27/15 10:38 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
If your going to get a remanufactured starter REMY is a very good brand,stay away from A1-CARDONE.
Re: one more quick mini starter question! [Re: MidPenMopar] #1884725
08/04/15 12:03 AM
08/04/15 12:03 AM
So i just noticed when i pulled the old mini starter out that it has an adapter plate and the new one i bought did not come with one. I would assume that since they are identical you need that adapter plate to shorten the throw of the mini vs OEM style.
But what do you do it you are switching for the first time and dont have one. I would imagine you are dead in the water. I looked on Summit and i could not find anywhere that says you need the adapter. Very strange indeed..... shruggy
Re: one more quick mini starter question! [Re: MidPenMopar] #1884910
08/04/15 01:02 PM
08/04/15 01:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Never saw any plates.Just install them just like the big starters.Only thing you have to remove the plastic piece on the lugs for most.I had to shorten the large lug a bit to clear my block.Have a pic of the plate?Rocky
Chrysler Firepower
Re: one more quick mini starter question! [Re: therocks] #1884956
08/04/15 02:03 PM
08/04/15 02:03 PM
Here is the plate that was on the old starter.
Re: one more quick mini starter question! [Re: MidPenMopar] #1884966
08/04/15 02:14 PM
08/04/15 02:14 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
I've put three of them on never have had a plate like that or even heard mention of it. I also like to use the stud like it came from the factory for the top bolt. Makes it easier to hang in place before putting the other bolt in.
Re: one more quick mini starter question! [Re: MidPenMopar] #1884968
08/04/15 02:16 PM
08/04/15 02:16 PM
Ok mystery solved, as i just was informed that due to my having the 4L60 transmission, i need that adapter. Otherwise if it was going in a 727, i would not use it.
Oils well that ends well!
