Re: Dash Meets Firewall and Windshield
[Re: RoadrunnerCN]
#188385
01/09/09 10:49 AM
01/09/09 10:49 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
If its anything like a 70 Charger you will have about 8 bolts where the windshield meets the dash frame, the 2 bolts down by the kick panels (one on each side) Thats all thats really holding it in. You might have a rod with eyelots around the steering column joining it to the steering brace.
They are bolted in with keps nuts/retainers. Its not that bad....Probably the worst part of it all is dealing with the wiring nightmare when you diconnect it all but with a service diagram and good labeling you'll be okay. I did the dash removal three times and three times they went back in okay (except my 69, I had to custom make a wiring harness with my own solid color wiring scheme and soldering everything instead of those factory crimping methods)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
