Dash Meets Firewall and Windshield #188384
01/09/09 10:35 AM
01/09/09 10:35 AM
Kentucky, USA
RoadrunnerCN Offline OP
Kentucky, USA
I'm going to replace my windshield on my 1970 Satellite and when I do, I'm going to replace the dash board...the whole unit that includes the framework of the entire dash. My question is this: I've never done this before and am wondering if the dash unit attaches to the firewall where the windshields sits on it by bolts or is it welded? Am I going to have to cut it and reweld or will it come unbolted? Have any of you ever done that before and if so, how much of a royal pain is it? Any other suggestions are appreciated (like "label all your wiring" or "you will or won't have to remove the steering column" etc.) Thanks! Chris.
Re: Dash Meets Firewall and Windshield [Re: RoadrunnerCN] #188385
01/09/09 10:49 AM
01/09/09 10:49 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
If its anything like a 70 Charger you will have about 8 bolts where the windshield meets the dash frame, the 2 bolts down by the kick panels (one on each side) Thats all thats really holding it in. You might have a rod with eyelots around the steering column joining it to the steering brace.
They are bolted in with keps nuts/retainers. Its not that bad....Probably the worst part of it all is dealing with the wiring nightmare when you diconnect it all but with a service diagram and good labeling you'll be okay. I did the dash removal three times and three times they went back in okay (except my 69, I had to custom make a wiring harness with my own solid color wiring scheme and soldering everything instead of those factory crimping methods)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Dash Meets Firewall and Windshield [Re: RoadrunnerCN] #188386
01/09/09 01:37 PM
01/09/09 01:37 PM
BRawls Offline
super gas
BRawls  Offline
super gas
It's held on by bolts. There are 7 or 8 at the dash/windshield seam and then 1 or 2 under the dash at the sides. Once you have the windshield removed, it's very easy to do.
Re: Dash Meets Firewall and Windshield [Re: BRawls] #188387
01/09/09 02:01 PM
01/09/09 02:01 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
You will need to drop the steering column also.
NMCA NSS 67 Coronet
Re: Dash Meets Firewall and Windshield [Re: Barry70GTX] #188388
01/09/09 02:32 PM
01/09/09 02:32 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
These are basic instructions, not specific to this model.
Pull the kick panels, there is a bolt on each side.
Remove the steering column.
Disconnect the firewall bulkhead on both sides, and the wiring harness underneath that goes back.
Disconnect the heater control cables from the box.
Disconnect the defroster hoses.
Disconnect the antenna from the radio.
Remove the windshield.
Put a few blankets over the console and/or seats.
Loosen but don't remove the side bolts.
Remove the bolts at the top of the instrument panel.
With a helper, tilt down the panel, lift off of the side bolts and remove panel. Make sure nothing else is connected while doing this.
Re: Dash Meets Firewall and Windshield [Re: RodStRace] #188389
01/09/09 04:17 PM
01/09/09 04:17 PM
Kentucky, USA
Kentucky, USA
I've said it before and I'll say it again. Thank God for this forum and for your answers. You guys are great. Thanks a bunch for your help. Well...winter project time. I'll keep watching in case some of the rest of you want to chime in. Again, really appreciate it! Chris.
Re: Dash Meets Firewall and Windshield [Re: RoadrunnerCN] #188390
01/09/09 07:11 PM
01/09/09 07:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Don't forget to change the VIN tag.
Re: Dash Meets Firewall and Windshield [Re: stumpy] #188391
01/09/09 08:27 PM
01/09/09 08:27 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
and get it done before you reinstall the windsheild. Don't ask me how I know!
