Where to buy 3.79 stroker pistons #1880230
07/28/15 06:44 PM
07/28/15 06:44 PM
Ky
moparmafia Offline OP
Ky
This is my first small block build and I am looking to buy a new set of pistons and h beam rods for a 340 with a 3.79 crank. where would be the best place to purchase these.I want something that will hold up with a small shot of spray.
Re: Where to buy 3.79 stroker pistons [Re: moparmafia] #1880239
07/28/15 06:57 PM
07/28/15 06:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What deck.. what rod length... for my 9.56 deck and chevy rods
I used Diamond pistons... call them and tell them all your facts
and that you might spray
wave
Re: Where to buy 3.79 stroker pistons [Re: moparmafia] #1880486
07/29/15 01:10 AM
07/29/15 01:10 AM
SoCal
Brian Hafliger Offline
SoCal
I use Diamond and now CP...if they have a shelf piston you like they can make a CD change for the 3.79 crank.
I also use 6.200 rods most times.
Brian
Brian Hafliger
Re: Where to buy 3.79 stroker pistons [Re: Brian Hafliger] #1880489
07/29/15 01:19 AM
07/29/15 01:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian
I built 3 3.79 engines.. 1 was a 9.2 block.. that one
I used Eagle 6.125 chevy H-beams with CP pistons.. the
2nd was a 9.56 block with chevy longer H-beam rods and
CP pistons.. the last was much like the 2nd but with
Diamond pistons
wave
Re: Where to buy 3.79 stroker pistons [Re: MR_P_BODY] #1880498
07/29/15 01:45 AM
07/29/15 01:45 AM
SoCal
SoCal
Right now CP is working with us on piston/rod/stroke combos and ring stacks...for very reasonable prices as piston/ring kits.
When we use Diamond pistons, we sub the rings out for Hastings...the CP's come with their own made by Mahle I think which is also a good choice.
Brian
Brian Hafliger
Re: Where to buy 3.79 stroker pistons [Re: moparmafia] #1880844
07/29/15 03:34 PM
07/29/15 03:34 PM
Fresno CA.
cortsGTS Offline
cortsGTS  Offline
Fresno CA.
Hughes Engines
Re: Where to buy 3.79 stroker pistons [Re: Brian Hafliger] #1880847
07/29/15 03:36 PM
07/29/15 03:36 PM
dogdays Offline
dogdays  Offline
Basically you're in smallblock chevy territory. Valve pockets are different and the rod journal is a tiny bit off but then you are in tall cotton. for example a 350 piston with 1.565 comp height plus the 6.125 chevy style rod plus the 3.79 crank has a height of 9.585.
Or probably spend more money for stuff mean for Mopars.
Ask Streetwize.
R.
Re: Where to buy 3.79 stroker pistons [Re: dogdays] #1882661
08/01/15 01:59 AM
08/01/15 01:59 AM
Australia
Teamx Offline
Teamx  Offline
Australia
I had these Diamond Pistons #83166 made for a 3.79 stroke 340
Pin height:1.400
Bore 4.070
Dish 9.3cc
Rod 6.300in SBC
These pistons are .005 down the hole and will give you aprox. 10.75 comp. with a zero deck a .040 head gasket and a 65cc chamber head. Makes 394ci while still maintaining a good rod to stroke ratio.
Re: Where to buy 3.79 stroker pistons [Re: moparmafia] #1882757
08/01/15 10:23 AM
08/01/15 10:23 AM
Maryland, USA
Raymond Offline
Raymond  Offline
Maryland, USA
I have a set of mahle power pack 4.08 bore.
1.25 comp.height for a chevy style rods.
cheap.
Re: Where to buy 3.79 stroker pistons [Re: moparmafia] #1882766
08/01/15 10:46 AM
08/01/15 10:46 AM
Maryland, USA
Raymond Offline
Raymond  Offline
Maryland, USA
I also have seven with a 4.06 bore
