Re: Harmonic Balancer .. which one??
[Re: Dduster]
#1882650
08/01/15 01:41 AM
08/01/15 01:41 AM
Posts: 43,275 Bend,OR USA
Cab_Burge
ATI three ring for the race motors They offer aluminum as well as steel, I have two now(one for a 539 C.I. B1 motor and one for a B1-MC 555 C.I. Koleno block) both are seroius bracket race motors with the steel hub and aluminum outers If you need a part number let me know, I'll give you both #s
[Re: Dduster]
#1882676
08/01/15 02:28 AM
08/01/15 02:28 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
http://www.innovatorswest.com/ this on my 439 ATI on my 360 TCI rattler on my old 498. appears I'm a harmonic balancer w-h-o-r-e of some sorts...
[Re: Dduster]
#1882726
08/01/15 05:55 AM
08/01/15 05:55 AM
Posts: 4,457 Washington
madscientist
Washington
If you want hype, go with ati.
And if you would rather go with real world, documented dampners than you should be looking at Fluidampr. When u need a reliable piece, its Fluidam iable piece, irt's fljddkrtorks a
[Re: Dduster]
#1882787
08/01/15 11:46 AM
08/01/15 11:46 AM
Posts: 7,506 Az
Crizila
Az
Need to buy harmonic balancer for new rb 493" race motor. Which is the favorite or best recommended? ATI. BHJ, TCI or Fluidampr? I run a Fluidamper on my blower motor.
Fastest 300
[Re: Dduster]
#1882788
08/01/15 11:48 AM
08/01/15 11:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks Cab. I appreciate your input. Are You going to run the Nightfire race in Boise (Eagle,ID) in a couple of weeks? I'm probably gonna scam together an excuse to get up to Boise for Work. I like Thunderbird Raceway and the Div 6 folks but it is so different in layout from Sac and Sonoma and Famoso in Pit size. Just different that's all. I would use the ATI..first choice... I also have 2 engines with Fluidampers on them.... spacing is the only issue you will have
[Re: Dduster]
#1882794
08/01/15 12:08 PM
08/01/15 12:08 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I really like that ATI will build what you want you don't have to buy what ever Summit has on the shelf.
The last one I got is a 6.1 Gen3 hemi hub, smooth alum shell, chevy 3 bolt face. They have a lot of options and will gladly help you get what you need.
"Just a Bracket car dressed up like a streetcar"
[Re: J_BODY]
#1882918
08/01/15 04:05 PM
08/01/15 04:05 PM
Posts: 7,506 Az
Crizila
Az
I do find it interesting that when you search "broken crankshaft" you'll find discussions around the Fluidampr brand. Even some of the threads at Speedtalk discuss this. Makes you think.... "Oh no. Mr Bill!!" - and don't forget to mention how they are effected by cold weather - and they leak.
Fastest 300
[Re: J_BODY]
#1882932
08/01/15 04:39 PM
08/01/15 04:39 PM
MR_P_BODY
I do find it interesting that when you search "broken crankshaft" you'll find discussions around the Fluidampr brand. Even some of the threads at Speedtalk discuss this. Makes you think.... Funny that I never broke anything when running them...and thats up to 8600 rpm.. EDIT its been on 3 engines now.. 340, 396, and now my 416... I'll let you know when I break a crank
[Re: MR_P_BODY]
#1882936
08/01/15 04:42 PM
08/01/15 04:42 PM
Posts: 7,506 Az
Crizila
Az
I do find it interesting that when you search "broken crankshaft" you'll find discussions around the Fluidampr brand. Even some of the threads at Speedtalk discuss this. Makes you think.... Funny that I never broke anything when running them...and thats up to 8600 rpm.. Mine put a crack in my Visa card.
Fastest 300
[Re: Crizila]
#1882937
08/01/15 04:45 PM
08/01/15 04:45 PM
MR_P_BODY
I do find it interesting that when you search "broken crankshaft" you'll find discussions around the Fluidampr brand. Even some of the threads at Speedtalk discuss this. Makes you think.... Funny that I never broke anything when running them...and thats up to 8600 rpm.. Mine put a crack in my Visa card. I have used ATI... mainly for 1 reason.... its lighter.. and that engine went to 9600 a couple of times... but normal was 8400
