Page 1 of 3 1 2 3
Harmonic Balancer .. which one?? #1882587
08/01/15 12:16 AM
08/01/15 12:16 AM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
Need to buy harmonic balancer for new rb 493" race motor. Which is the favorite or best recommended? ATI. BHJ, TCI or Fluidampr?
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882650
08/01/15 01:41 AM
08/01/15 01:41 AM
ATI three ring for the race motors up They offer aluminum as well as steel, I have two now(one for a 539 C.I. B1 motor and one for a B1-MC 555 C.I. Koleno block) both are seroius bracket race motors with the steel hub and aluminum outers scope If you need a part number let me know, I'll give you both #s up
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882672
08/01/15 02:21 AM
08/01/15 02:21 AM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
Thanks Cab. I appreciate your input. Are You going to run the Nightfire race in Boise (Eagle,ID) in a couple of weeks? I'm probably gonna scam together an excuse to get up to Boise for Work. I like Thunderbird Raceway and the Div 6 folks but it is so different in layout from Sac and Sonoma and Famoso in Pit size. Just different that's all.
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882676
08/01/15 02:28 AM
08/01/15 02:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.innovatorswest.com/ this on my 439
ATI on my 360
TCI rattler on my old 498.
appears I'm a harmonic balancer w-h-o-r-e of some sorts...
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882726
08/01/15 05:55 AM
08/01/15 05:55 AM
Washington
madscientist Offline
Washington
If you want hype, go with ati.
And if you would rather go with real world, documented dampners than you should be looking at Fluidampr. When u need a reliable piece, its Fluidam
iable piece, irt's fljddkrtorks a
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882781
08/01/15 11:33 AM
08/01/15 11:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'll pass on Fluidampr.... kind of like I wouldn't buy a PTC converter. Lots of love for the product, but I've seen others with repeated bad results from going down that road.
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882787
08/01/15 11:46 AM
08/01/15 11:46 AM
Az
Crizila Offline
Crizila  Offline
Az
I run a Fluidamper on my blower motor.
Fastest 300
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882788
08/01/15 11:48 AM
08/01/15 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would use the ATI..first choice... I also have 2 engines
with Fluidampers on them.... spacing is the only issue you
will have
wave
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882794
08/01/15 12:08 PM
08/01/15 12:08 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I really like that ATI will build what you want you don't have to buy what ever Summit has on the shelf.
The last one I got is a 6.1 Gen3 hemi hub, smooth alum shell, chevy 3 bolt face. They have a lot of options and will gladly help you get what you need.
"Just a Bracket car dressed up like a streetcar"
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882876
08/01/15 02:51 PM
08/01/15 02:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I do find it interesting that when you search "broken crankshaft" you'll find discussions around the Fluidampr brand. Even some of the threads at Speedtalk discuss this. Makes you think....
Re: Harmonic Balancer .. which one?? [Re: J_BODY] #1882918
08/01/15 04:05 PM
08/01/15 04:05 PM
Az
Crizila Offline
Crizila  Offline
Az
"Oh no. Mr Bill!!" eek - and don't forget to mention how they are effected by cold weather - and they leak. blah
Fastest 300
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882926
08/01/15 04:22 PM
08/01/15 04:22 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
ATI here
Re: Harmonic Balancer .. which one?? [Re: J_BODY] #1882932
08/01/15 04:39 PM
08/01/15 04:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Funny that I never broke anything when running them...and thats up
to 8600 rpm..
EDIT
its been on 3 engines now.. 340, 396, and now my 416...
I'll let you know when I break a crank
wave
Re: Harmonic Balancer .. which one?? [Re: MR_P_BODY] #1882936
08/01/15 04:42 PM
08/01/15 04:42 PM
Az
Crizila Offline
Crizila  Offline
Az
to 8600 rpm..
wave
Mine put a crack in my Visa card. whiney
Fastest 300
Re: Harmonic Balancer .. which one?? [Re: Crizila] #1882937
08/01/15 04:45 PM
08/01/15 04:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
to 8600 rpm..
wave
I have used ATI... mainly for 1 reason.... its lighter..
and that engine went to 9600 a couple of times... but normal
was 8400
wave
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882948
08/01/15 04:58 PM
08/01/15 04:58 PM
Walhalla, SC
BlueDart Offline
BlueDart  Offline
Walhalla, SC
Well my Fluidamper is on it's 3rd engine since 1997 bracket motors with countless runs them the bearings on the last engine looked good enough to use again after 12 years
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882954
08/01/15 05:07 PM
08/01/15 05:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've never used a Fluidampr..... just did a casual search after reading this post and was surprised by the comments and discussions at various forums. Get any more wound up Crizilla and I'll continue to secretly stalk you at NHRA events so that I can continue spilling beer on you.
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1882965
08/01/15 05:27 PM
08/01/15 05:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Alcohol abuse !!!
Re: Harmonic Balancer .. which one?? [Re: J_BODY] #1883012
08/01/15 06:34 PM
08/01/15 06:34 PM
Az
Crizila Offline
Crizila  Offline
Az
laugh laugh - you're gonna make me pee!!!
Fastest 300
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1883019
08/01/15 06:38 PM
08/01/15 06:38 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
the boredom of summer is setting in.... smile
Page 1 of 3 1 2 3
