Big or small oil filter for 383? #1882588
08/01/15 12:16 AM
08/01/15 12:16 AM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
Are there any problems with using a regular-sized(big) oil filter on a '70 383 stock build engine opposed to the half-sized(small)filter? Again, stock oil pump capacity and stock 402 oil pan, etc.
Re: Big or small oil filter for 383? [Re: 69/70 Plymies] #1882593
08/01/15 12:24 AM
08/01/15 12:24 AM
I'd suggest the largest wix brand filter that will fit
Re: Big or small oil filter for 383? [Re: RapidRobert] #1882601
08/01/15 12:31 AM
08/01/15 12:31 AM
midwest - USA
midwest - USA
Wix #51515 fits. Should I add a little more oil than the standard 5 qt. in order to keep the dipstick on the full mark?
Re: Big or small oil filter for 383? [Re: 69/70 Plymies] #1882631
08/01/15 01:23 AM
08/01/15 01:23 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
They came with 1qt filters such as the Wix 51515 from the factory.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Big or small oil filter for 383? [Re: 69/70 Plymies] #1882821
08/01/15 12:52 PM
08/01/15 12:52 PM
Yes, with the car level you want it full no matter how much capacity your choice of filter has. slightly adj the amt you add till you get there. the 5 qt figure is a nominal number
Re: Big or small oil filter for 383? [Re: moparmarks] #1883567
08/02/15 03:12 PM
08/02/15 03:12 PM
midwest - USA
midwest - USA
I like the idea of the larger filter and will be what I use. However, I seen on the WIX website the 51515 is listed for small blocks, 440 and 426 hemi. For the 383, they list the small-type 51068.
Thanks for the advice Moparts members!
Re: Big or small oil filter for 383? [Re: 69/70 Plymies] #1883579
08/02/15 03:28 PM
08/02/15 03:28 PM
BDW Online content
BDW  Online Content
There's larger.........
Re: Big or small oil filter for 383? [Re: 69/70 Plymies] #1884376
08/03/15 03:44 PM
08/03/15 03:44 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
515 fits with federal pump and manual boxes. 068 fits with saginaw pump.
I want my fair share
Re: Big or small oil filter for 383? [Re: 69/70 Plymies] #1885295
08/04/15 11:51 PM
08/04/15 11:51 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
Small block filter will fit but hard to get off due to k frame. The big block sticks out past the k frame, making it easier to grab.
