Best Block Enough? #1882275
07/31/15 03:21 PM
07/31/15 03:21 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Well after the "cracked mains/aluminum cap" debate.
I tore down a core I`ve had for a LONG time,turns out its a 4006630 THICK WEB block.
So supposedly this a "good" RB block. Caps were nice and tight no obvious cap walk.
So IF it checks out crack free this is a good thing.
So now build options:
3.75stroke 440 11.75cr. 6,700 max trap RPM.4.88 gear cheapest
4.25 stroke 7.1 rod 10.5cr 6,400 trap 4.56 gear
4.15 stroke 6.76 rod 10.5 cr------------
I have the BCR caps,,,, necessary?
I have also found 2 400 cores local for 200 bucks each.
That is an potion too,but would require more cash for intake,push rods ,dist etc...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Best Block Enough? [Re: 6bblFLASH] #1882357
07/31/15 05:22 PM
07/31/15 05:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Low deck and forget about it......ya it cost but what doesn`t in this game and how many 400 blocks do you see having these problems. I even know of 8-second turbo guy w/a 400 and stock caps.......
Re: Best Block Enough? [Re: 6bblFLASH] #1882447
07/31/15 08:09 PM
07/31/15 08:09 PM
gregsdart Offline
gregsdart  Offline
I agree with Dom, but an option is to build the 440 block you have, and back it up with a 4.10 or 4.30 gear or what ever gets the revs down to 6200 for the 440, or 5800 for the 4.25 stroke combo. Unless you go to big port heads, or a very long duration cam, you don't need to rev a 440 over 6200, and maybe less. Use the longest rod you can, and if you choose to go 4.25 stroke you can bring the rpm down more, to 5600 to 5800.
Re: Best Block Enough? [Re: gregsdart] #1882463
07/31/15 08:47 PM
07/31/15 08:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep goin on 13 years even into detonation at 17.1 and still no cracks or major cap walk.......
Re: Best Block Enough? [Re: 6bblFLASH] #1882475
07/31/15 09:25 PM
07/31/15 09:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I would build the 440 since you have the parts...
when you get the cash then build the 400 block... just
dont let the 440 detonate
wave
Re: Best Block Enough? [Re: 6bblFLASH] #1882508
07/31/15 10:11 PM
07/31/15 10:11 PM
The block in your pictures is not a 400, it is a 440 block with the last three numbers in the casting number "440", not "400". The supposidely(SP?) best 400 blocks are the cold weather)1971 castings from June of 1971 to September or October "230" castings with the really large casting numbers, the others after that are the 3614230 casting numbers used up to around 1973 or 1974. The casting numbers I have on 400 blcoks after that are either 400530-400-1 or -2 castings shruggy All Mopar blocks should have a casting date on one side like 12-9-75 or 2-16-72 scope That will tell you the day, month and year that block was cast in up All 400 BLOCKS should have all the cylinders sonic tested before boring up twocents I had a 230 casting(not sonic tested properly runaway) split a cylinder wall on the dyno, it had really bad core shift on the drivers side and wasn't saveable whiney shruggy IHTHs up
Re: Best Block Enough? [Re: Cab_Burge] #1882554
07/31/15 11:24 PM
07/31/15 11:24 PM
N.E. Ohio
N.E. Ohio
Thanks Cab,,,,you see as bad as ME scope
I said RB block,yes that is a 440,have never owned anything else...
On 440 Source they talk about a "630" late 440 that has .500 web instead of .375.Not all "630" blocks are thicker... This is one of those thicker blocks I have.
Its a "virgin" core STD. STD.STD..
If the hype it true this the "best" production 440 as far as web thickness.
Re: Best Block Enough? [Re: 6bblFLASH] #1882590
08/01/15 12:20 AM
08/01/15 12:20 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By 6bblFLASH
[quote=Cab_Burge]
You are correct, it does have the Slightly thicker web. Not nearly as good as the 400,s but better.
In your shoes I would do that engine myself too. What the last one lasted 30 years you say? If this one lasts you another 30 years its going to outlast you.lol
Build it with the 4.25 crank, and the other parts you have.
Re: Best Block Enough? [Re: Sport440] #1882595
08/01/15 12:25 AM
08/01/15 12:25 AM
N.E. Ohio
N.E. Ohio
Sport,,, no this one didn`t last 30 years,,I wish boogie
its the 1st block I`ve had break. hammer
Re: Best Block Enough? [Re: Cab_Burge] #1884950
08/04/15 01:51 PM
08/04/15 01:51 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Does anybody have a picture of the really large casting numbers that Cab is talking about?
2011 Drag Pak Challenger
Re: Best Block Enough? [Re: 6bblFLASH] #1885038
08/04/15 04:27 PM
08/04/15 04:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd fill it, then put a 440source stroker kit in it.
Re: Best Block Enough? [Re: rickseeman] #1885232
08/04/15 10:25 PM
08/04/15 10:25 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Here's one I have
