Rebuilt engine, no compression, spitting gas, help
#1882386
07/31/15 06:19 PM
07/31/15 06:19 PM
Posts: 170 Western., NY
sco440
Western., NY
Newly rebuilt 440. Went to start for the first time and it is not building up any compression, is spitting gas through the Eddy carb. It was completely rebuilt all new parts basically to stock. Is this a camshaft issue? THX
'72 Road Runner '72 Dart Swinger 340 '12 Challenger R/T
Re: Rebuilt engine, no compression, spitting gas, help
[Re: sco440]
#1882396
07/31/15 06:29 PM
07/31/15 06:29 PM
Challenger 1
Cincinnati, Ohio
Newly rebuilt 440. Went to start for the first time and it is not building up any compression, is spitting gas through the Eddy carb. It was completely rebuilt all new parts basically to stock. Is this a camshaft issue? THX Lifter pre load, did you check it?
[Re: sco440]
#1882406
07/31/15 06:40 PM
07/31/15 06:40 PM
Posts: 152 usa
smos001
usa
[Re: stumpy]
#1882528
07/31/15 10:38 PM
07/31/15 10:38 PM
RapidRobert
I would regoop the cam. set dampener at 15 BTDC. check the lobes when you regoop to see if you are on #1 or #6 compression & clock the rotor accordingly. turn housing so magnet is dead even with the tooth. make a mark on the dampener 2&7/32" CW from the TDC slit & have your dist man set it to that when it fires (vac adv capped). carb bowls filled. batt charged. fan in front of rad. front end jacked up. thermostat OUT. read "breakin secrets" at www.mototuneusa.com goose the throttle many many times during the 25 minute breakin. during mockup confirm lifters are free to rotate (hughes engines procedure).
[Re: sco440]
#1882635
08/01/15 01:29 AM
08/01/15 01:29 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Who rebuilt it? If you did the build did you install the cam with the dots on the gears or did you install the cam and and degree it? If with the dots on the gears did you aligned the crank gear dot out under the teeth or the one on the inside above the crankshaft key? If the one above the key you need to use the one on the outer edge of the crank gear. If you didn't do the build call the one who did and tell them to come fix it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Let us know what youy find and do, it will help a lot of others on here also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: sco440]
#1882910
08/01/15 03:38 PM
08/01/15 03:38 PM
sco440
Western., NY
I have some compression maybe 50 lbs not enough for it to run.. I think the engine builder didn't perfectly line up the dots on the cam and crank sprockets when he put the timing chain on.
[Re: sco440]
#1882994
08/01/15 06:18 PM
08/01/15 06:18 PM
Cab_Burge
To make it spit gas up out of the carb while cranking on the starter the valves have to be opened ![work work](/ubbthreads/images/graemlins/custom/work.gif) The cam is out of time, have the builder correct it or maybe have someone who knows more than your builder help you reinstall the timing gears and align the dots proeprly ![work work](/ubbthreads/images/graemlins/custom/work.gif) I think you should really degree the cam for the best performance also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Cab_Burge]
#1883267
08/02/15 01:45 AM
08/02/15 01:45 AM
RapidRobert
What Cab said, if it is dot to dot (correct dots that is!) it'd still have good compression even with the dist 180 out. With a multiple keyway gearset its confused some to line up the cam gear wrong. inner marks are for adv/ret/straight up phasing. outer marks (closer to perimeter) are for dot to dot
[Re: RapidRobert]
#1883307
08/02/15 02:41 AM
08/02/15 02:41 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If the wrong dot was used in 'dot to dot' the cam can be as much as 30 degrees advanced/retarded. Recipie for Pistons to hit valves. DAMHIK.
**Photobucket sucks**
