Rebuilt engine, no compression, spitting gas, help #1882386
07/31/15 06:19 PM
07/31/15 06:19 PM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
Newly rebuilt 440. Went to start for the first time and it is not building up any compression, is spitting gas through the Eddy carb. It was completely rebuilt all new parts basically to stock. Is this a camshaft issue? THX
'72 Road Runner
'72 Dart Swinger 340
'12 Challenger R/T
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882396
07/31/15 06:29 PM
07/31/15 06:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Lifter pre load, did you check it?
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882398
07/31/15 06:30 PM
07/31/15 06:30 PM
usa
smos001 Offline
smos001  Offline
usa
Sounds like a cam timing issue... valves are stuck open... also check valve lash if you have adjustable rockers (did you say all stock?). check for bent push rods. If the cam is off timing you could bend them.
who built the engine? Did they break it in yet?
Good Luck,
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882400
07/31/15 06:32 PM
07/31/15 06:32 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
spitting thru the carb may mean the distributor is 180 out. simple fix.
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882406
07/31/15 06:40 PM
07/31/15 06:40 PM
usa
smos001 Offline
smos001  Offline
usa
No compression?
Re: Rebuilt engine, no compression, spitting gas, help [Re: smos001] #1882407
07/31/15 06:42 PM
07/31/15 06:42 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Good Luck,
iagree Cam timed wrong.
Re: Rebuilt engine, no compression, spitting gas, help [Re: stumpy] #1882528
07/31/15 10:38 PM
07/31/15 10:38 PM
I would regoop the cam. set dampener at 15 BTDC. check the lobes when you regoop to see if you are on #1 or #6 compression & clock the rotor accordingly. turn housing so magnet is dead even with the tooth. make a mark on the dampener 2&7/32" CW from the TDC slit & have your dist man set it to that when it fires (vac adv capped). carb bowls filled. batt charged. fan in front of rad. front end jacked up. thermostat OUT. read "breakin secrets" at www.mototuneusa.com goose the throttle many many times during the 25 minute breakin. during mockup confirm lifters are free to rotate (hughes engines procedure).
Re: Rebuilt engine, no compression, spitting gas, help [Re: RapidRobert] #1882614
08/01/15 12:45 AM
08/01/15 12:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You are probably very frustrated but you'll need to give more info if you want any useful help.
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882635
08/01/15 01:29 AM
08/01/15 01:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
Who rebuilt it? If you did the build did you install the cam with the dots on the gears or did you install the cam and and degree it? If with the dots on the gears did you aligned the crank gear dot out under the teeth or the one on the inside above the crankshaft key? If the one above the key you need to use the one on the outer edge of the crank gear. If you didn't do the build call the one who did and tell them to come fix it up Let us know what youy find and do, it will help a lot of others on here also up
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882910
08/01/15 03:38 PM
08/01/15 03:38 PM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
I have some compression maybe 50 lbs not enough for it to run.. I think the engine builder didn't perfectly line up the dots on the cam and crank sprockets when he put the timing chain on.
'72 Road Runner
'12 Challenger R/T
Re: Rebuilt engine, no compression, spitting gas, help [Re: sco440] #1882994
08/01/15 06:18 PM
08/01/15 06:18 PM
To make it spit gas up out of the carb while cranking on the starter the valves have to be opened shock work The cam is out of time, have the builder correct it or maybe have someone who knows more than your builder help you reinstall the timing gears and align the dots proeprly work I think you should really degree the cam for the best performance also up
Re: Rebuilt engine, no compression, spitting gas, help [Re: Cab_Burge] #1883267
08/02/15 01:45 AM
08/02/15 01:45 AM
What Cab said, if it is dot to dot (correct dots that is!) it'd still have good compression even with the dist 180 out. With a multiple keyway gearset its confused some to line up the cam gear wrong. inner marks are for adv/ret/straight up phasing. outer marks (closer to perimeter) are for dot to dot
Re: Rebuilt engine, no compression, spitting gas, help [Re: RapidRobert] #1883307
08/02/15 02:41 AM
08/02/15 02:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If the wrong dot was used in 'dot to dot' the cam can be as much as 30 degrees advanced/retarded. Recipie for Pistons to hit valves. DAMHIK.
**Photobucket sucks**
