Anybody know how to get the warp out of this grille? #1879446
07/27/15 08:10 PM
07/27/15 08:10 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
My 72 road runner grille
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1879477
07/27/15 08:50 PM
07/27/15 08:50 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
find a replacement..
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1879549
07/27/15 10:13 PM
07/27/15 10:13 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Yeah right away.
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1879567
07/27/15 10:26 PM
07/27/15 10:26 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted By RV2
Yeah right away.
laugh2 No doubt. beer
You may want to Google it, but I did hear on here quite awhile back, that you can put it in a bathtub full of hot water and it might come back to shape.
Mo' Farts
Moderated by "tbagger".
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1879876
07/28/15 10:44 AM
07/28/15 10:44 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
you will need to heat it to straighten it out.
warm it up, place something straight over the bend and let it cool.
you need to heat the entire grill to get it to straighten out. so a heat gun probably won't work.
I work in a body shop so heating with a heat lamp would be easy.
you might try putting it in a oven to warm it up. set it at about 250* and see what happens.
maybe try a forced air heater to warm it.
for what 72 RR grills cost IF you can find one. it might be cheaper to buy a heat lamp to straighten it than buying a good grill.
perception is 90% of reality
Re: Anybody know how to get the warp out of this grille? [Re: Mr T2U] #1880431
07/29/15 12:04 AM
07/29/15 12:04 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
As a bystander on the sidelines, would leaving it under a watchful eye in this hot July sun and then carefully clamping it to some kind of wooden jig and allowing it to cool in the shade be of any help? Or would that aid in making it brittle and fragile with the sun's UV rays?
Common sense is a flower that does not grow in everybody's garden
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1880487
07/29/15 01:10 AM
07/29/15 01:10 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Heat from the sun at the earth's surface just ain't gonna do it !! Hot water - at boiling will only be about 212 degrees depending on your altitude - ain't gonna do it either. Got a big enough oven ... that may be your best bet.
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1880586
07/29/15 10:34 AM
07/29/15 10:34 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That ABS looks to have been through a heat cycle beyond it's melt point (such as in a fire), if that's the case it's junk. If it's warped from being contorted and held in place such as in an accident where metal moved it and held it in place for a long enough time for it to hold a set, then heat MIGHT give it a chance that warming it will allow the plastic "memory" to bring it back into place, then I agree, a carefully controlled heat cycle below the melt temp in an oven is your best chance but it's severe looking enough that I doubt it will work. .02
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1942694
11/01/15 03:15 AM
11/01/15 03:15 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
The grill is supposed to have 4 studs made in it that come out at an angle with a nut that cuts its own thread to hold it flat across the bumper. They are usually broke off.
To replace the studs, I have used machine screws with the heads ground to fit in the hollow raised squares across the bottom. I used a washer and nylock nut to hold it.
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1943390
11/02/15 12:38 AM
11/02/15 12:38 AM
northwest49
feeeighteefee Offline
northwest49
heat gun and a couple long pieces of 2 x3 's and some clamps and patience.heat to shape and then cool with compressed air.72 rr grilles are notorious for warping
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1943428
11/02/15 01:43 AM
11/02/15 01:43 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Thanks guys
Re: Anybody know how to get the warp out of this grille? [Re: RV2] #1943466
11/02/15 03:49 AM
11/02/15 03:49 AM
Alabama
BigMoneyLewis Offline
Alabama
Haaa, I KNEW it was going to be a '72 Road Runner grille before I clicked on this post. I had one warped alot worse than that . I never did get mine straight .
Greg
gregward@mchsi.com phone 256-852-0955
Re: Anybody know how to get the warp out of this grille? [Re: BigMoneyLewis] #1943526
11/02/15 10:49 AM
11/02/15 10:49 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
What I did on my 70 Charger grill that had a sag on one side was to epoxy a strip of Alum. 1/8 x 2" to the back side and clamp it straight.
After it dried it looked great! You may need something stronger for that length but it's worth a try....Joe
