Re: Anybody know how to get the warp out of this grille?
[Re: RV2]
#1879876
07/28/15 10:44 AM
07/28/15 10:44 AM
Posts: 4,910 new berlin wisconsin
Mr T2U
you will need to heat it to straighten it out. warm it up, place something straight over the bend and let it cool. you need to heat the entire grill to get it to straighten out. so a heat gun probably won't work. I work in a body shop so heating with a heat lamp would be easy.
you might try putting it in a oven to warm it up. set it at about 250* and see what happens.
maybe try a forced air heater to warm it.
for what 72 RR grills cost IF you can find one. it might be cheaper to buy a heat lamp to straighten it than buying a good grill.
perception is 90% of reality
[Re: Mr T2U]
#1880431
07/29/15 12:04 AM
07/29/15 12:04 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
As a bystander on the sidelines, would leaving it under a watchful eye in this hot July sun and then carefully clamping it to some kind of wooden jig and allowing it to cool in the shade be of any help? Or would that aid in making it brittle and fragile with the sun's UV rays?
Common sense is a flower that does not grow in everybody's garden
[Re: RV2]
#1880487
07/29/15 01:10 AM
07/29/15 01:10 AM
Posts: 8,828 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Heat from the sun at the earth's surface just ain't gonna do it !! Hot water - at boiling will only be about 212 degrees depending on your altitude - ain't gonna do it either. Got a big enough oven ... that may be your best bet.
