68 dart front suspension rebuild question #188056
01/08/09 06:46 PM
01/08/09 06:46 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I am rebuilding the front end on a 68 dart GT, i seem to have lost the piece on the lower control arm where it bolts into the K frame. it has a bushing on the arm and we were changing them and i cant find the piece now. it sat apart for 5 years.
i was wondering if anyone makes it or if a challenger may be the same if i took the arm off the old challenger i have and pulled the stud looking piece out of it where it bolts to the K frame?
any idea?
Re: 68 dart front suspension rebuild question [Re: dirt] #188057
01/08/09 06:51 PM
01/08/09 06:51 PM
i was wondering if anyone makes it or if a challenger may be the same if i took the arm off the old challenger i have and pulled the stud looking piece out of it where it bolts to the K frame? any idea?
you're in luck. grab one from the challenger LCA
Re: 68 dart front suspension rebuild question [Re: RapidRobert] #188058
01/08/09 07:40 PM
01/08/09 07:40 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
so the lower control arm stud that bolts into the k frame on a 68 dart is the same as a challenger?
i seen a set for sale but they were only listed for a E body or B body.possibly the guy did not know the studs were the same?
i looked up the bushings that go into the control arm for a challenger and a dart and they are the same so i wonder if the studs are the same?
Re: 68 dart front suspension rebuild question [Re: dirt] #188059
01/08/09 08:33 PM
01/08/09 08:33 PM
correct
