how do you test a bad starter while still on the car? #188027
01/08/09 05:56 PM
01/08/09 05:56 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
I bought this charger with a 440 from a guy who said that it ran when it was parked, that was 15 years ago. I got the car home and was going to try to start it but i all I get is a "clink" How do I test the starter? without taking it out
Re: how do you test a bad starter while still on the car? [Re: AK_JH27] #188028
01/08/09 06:12 PM
01/08/09 06:12 PM
Assuming that your batt is good & cables are clean(continuity) then with a screwdriver jump across the 2 terminals on the starter being carefull not to touch the case with the screwdriver
Re: how do you test a bad starter while still on the car? [Re: AK_JH27] #188029
01/08/09 06:14 PM
01/08/09 06:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the battery is fully charged and the cables are clean then you can short across the two starter terminals. Be sure to try turning the motor over with a breaker bar on the crank bolt before replacing the starter. Robert you sure are rapid.
Re: how do you test a bad starter while still on the car? [Re: stumpy] #188030
01/08/09 06:23 PM
01/08/09 06:23 PM
yes that did effect a bit of redundancy. good point stumpy, see if the eng is free 1st, 15 yrs is a long time especially in that moisture laden climate..
Re: how do you test a bad starter while still on the car? [Re: RapidRobert] #188031
01/08/09 06:28 PM
01/08/09 06:28 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
I did that, the motor turns over, I then tired jumping the solnoid:
the battery (B) lug to the wire below it (the other exposed wire) and got nothing. any thing else i can try.
Re: how do you test a bad starter while still on the car? [Re: AK_JH27] #188032
01/08/09 06:31 PM
01/08/09 06:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Does the "Click" come from the relay or the starter? Try rapping on the starter with a hammer..
Re: how do you test a bad starter while still on the car? [Re: 1_WILD_RT] #188033
01/08/09 07:00 PM
01/08/09 07:00 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
click comes from the relay nothing from the starter and i tapped it with a hammer also. still nothing.
Re: how do you test a bad starter while still on the car? [Re: AK_JH27] #188034
01/08/09 07:03 PM
01/08/09 07:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Then I would say replace it. They are cheap.
