933 oil pan. What to replace it with? #1880043
07/28/15 02:15 PM
07/28/15 02:15 PM
Monee IL
chicagotim2003 Offline OP
Monee IL
I have a 73 challenger. The 440 i have in it has a 933 stamped oil pan. From what i could find those were used on 74-78 440`s. Looking at jegs and summit there are a ton of options even for the stock pans. Baffle no baffle,oil pump etc etc. My car is at a good friends shop having the trans rebuilt. He said my oil pan is dented and he thinks i should replace it. Should i just have him pound out the dent or go with a new pan? Can you tell me a direct replacement? I know 440 source has some. Their chart says 933 not suited for a/b/e body. I assume it hangs a little low past the k frame. Probably why it got dented in the first place.
To top it off his shop is closed next week so i would have to have it overnighted! Direct replacement or pound out the dent.
Re: 933 oil pan. What to replace it with? [Re: chicagotim2003] #1880066
07/28/15 02:44 PM
07/28/15 02:44 PM
you definitely want baffled. just consider this a BTT for ya & wait for other BB chally owners to chime in with what they are running. As you know we dont want one hanging below the K
Re: 933 oil pan. What to replace it with? [Re: chicagotim2003] #1880076
07/28/15 02:59 PM
07/28/15 02:59 PM
Monee IL
Monee IL
Rapid robert i really want to thank you. I think every tech question i have asked you have responded. You have been dead on with your advice. Really appreciate your knowledge!!!! Also i would like to know how do you know so much about mopars? Were you a chrysler tech or just years of experience?
I just decided to have him pound the dent out. There is to much of a time crunch. I have to get this done by friday. If i get anything less then a perfect replacement it won`t end well. To shallow of a pan and ill have to get a diffrrent oil pump. From what i have read some 933 pans have baffles and some don`t. Not sure what`s in mine. As long as i have a good seal i can live with it. Maybe a project for a future date.
Any 440 ebody guys feel free to let me know what pan you have that works. As always thanks!!
Re: 933 oil pan. What to replace it with? [Re: chicagotim2003] #1880513
07/29/15 02:13 AM
07/29/15 02:13 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
1970 440/426 pan, I also made a K frame skid plate, 5mi of dirt road for 20yrs, a few scratches but my ride height is kinda tall.
Re: 933 oil pan. What to replace it with? [Re: chicagotim2003] #1880552
07/29/15 07:34 AM
07/29/15 07:34 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
........and he thinks i should replace it.
Why?
