What type mechanical fuel pump came on 472 crate Hemis? #187894
01/08/09 03:23 PM
01/08/09 03:23 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I picked up a mechanical fuel pump that originally came on a 472 crate Hemi.
It looks similar to the Carter high volumn fuel pump I currently have on one of my 440's.
The only markings on the pump are the numbers 869 and "Made in Canada".
I'm hoping to use this pump on a warmed over aluminum headed 440 sixpack engine I'm getting ready to install in the wife's Challenger.
Anyone know if this is a high volumn pump?
Thanks.
Re: What type mechanical fuel pump came on 472 crate He [Re: KillerBee] #187895
01/08/09 03:31 PM
01/08/09 03:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i would say it'sa high volume pump but i would check the pressure , I have seen people post that they got 9psi race pumps on their crate motors , chrysler had been using up anything old they had laying around for their crate motor program , at least that's how the mismatched hardware on my crate hemi from the CUMMINS recon era appears ...
Re: What type mechanical fuel pump came on 472 crate He [Re: JohnRR] #187896
01/08/09 03:40 PM
01/08/09 03:40 PM
N.E. Ohio
K
K
N.E. Ohio
I'm planning on running the fuel lines similar to my other 440 Sixpack Challenger. The out fuel line from the pump to a regulator then to a fuel pressure guage before the carbs.
I just hope this is a HP fuel pump.
Re: What type mechanical fuel pump came on 472 crate Hemis? [Re: KillerBee] #187897
01/08/09 06:37 PM
01/08/09 06:37 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Have you tried to mount it to your engine? The pump body hits on a Hemi and you have to grind a little material off to get it to seat.
Re: What type mechanical fuel pump came on 472 crate Hemis? [Re: KillerBee] #187898
01/08/09 06:44 PM
01/08/09 06:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Careful with that.
MP told Cummins not to use a fuel pump on crate Hemis. There was no fuel pump on the bill of materials. They were supposed to have a block off plate and nothing else.
Cummins Reman (Toronto Canada) in their infinite wisdom (???) sourced fuel pumps from God knows where, and most of them put out something ridiculous like 15psi. Hope you have a regulator.
I'm glad those days are over, MP's new contractor
Gary Stanton builds the 426 and 472 the way they should have been built all along.
So basically the pump is mystery meat...
Re: What type mechanical fuel pump came on 472 crate Hemis? [Re: ZIPPY] #187899
01/08/09 07:35 PM
01/08/09 07:35 PM
N.E. Ohio
K
K
N.E. Ohio
Wonderful
Is there anyway to bench test a fuel pump?
The pump was installed on the crate Hemi for a short time so I assume it fit without clearance issues
Re: What type mechanical fuel pump came on 472 crate He [Re: KillerBee] #187900
01/08/09 08:52 PM
01/08/09 08:52 PM
California
mickm Offline
mickm  Offline
California
looks exactly like the pump that came off of mine, even though mine wasn't a crate. it was putting about between 8-9 psi. but i don't see where it was ground to clear the block, so i can't be sure that it is the same.
Re: What type mechanical fuel pump came on 472 crate Hemis? [Re: KillerBee] #187901
01/08/09 08:57 PM
01/08/09 08:57 PM
no gotta run it but I would split it & rinse it out inside & check for anything amiss
Re: What type mechanical fuel pump came on 472 crate He [Re: mickm] #187902
01/08/09 09:11 PM
01/08/09 09:11 PM
N.E. Ohio
K
K
N.E. Ohio
Where exactly should I look on the pump for grinding for clearance?
Thanks.
Re: What type mechanical fuel pump came on 472 crate He [Re: KillerBee] #187903
01/08/09 09:15 PM
01/08/09 09:15 PM
you want the face of the pump to fit flat on the block with the bolt holes lined up & centered & if neccessary grind around the perimeter of the pump mounting face until it sits on the block flush.
Re: What type mechanical fuel pump came on 472 crate He [Re: RapidRobert] #187904
01/08/09 10:48 PM
01/08/09 10:48 PM
California
mickm Offline
mickm  Offline
California
looking at the pump face on to the bolts, the boss to the left has to be ground some to fit, otherwise it butts up against the block, and you can't line the holes up.
