Re: What type mechanical fuel pump came on 472 crate He
[Re: JohnRR]
#187896
01/08/09 03:40 PM
01/08/09 03:40 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
i would say it'sa high volume pump but i would check the pressure , I have seen people post that they got 9psi race pumps on their crate motors , chrysler had been using up anything old they had laying around for their crate motor program , at least that's how the mismatched hardware on my crate hemi from the CUMMINS recon era appears ...
I'm planning on running the fuel lines similar to my other 440 Sixpack Challenger. The out fuel line from the pump to a regulator then to a fuel pressure guage before the carbs. I just hope this is a HP fuel pump.
[Re: mickm]
#187902
01/08/09 09:11 PM
01/08/09 09:11 PM
KillerBee
N.E. Ohio
looks exactly like the pump that came off of mine, even though mine wasn't a crate. it was putting about between 8-9 psi. but i don't see where it was ground to clear the block, so i can't be sure that it is the same.
Where exactly should I look on the pump for grinding for clearance?
Thanks.
[Re: KillerBee]
#187903
01/08/09 09:15 PM
01/08/09 09:15 PM
RapidRobert
you want the face of the pump to fit flat on the block with the bolt holes lined up & centered & if neccessary grind around the perimeter of the pump mounting face until it sits on the block flush.
