Should I rebuild my 904 or look for a 727? #1877793
07/25/15 12:18 PM
07/25/15 12:18 PM
PA
P
plumcrazycuda Offline OP
P
PA
My 904 is gone bad! It only had first and reverse. Should I rebuild it or look for a 727?
Re: Should I rebuild my 904 or look for a 727? [Re: plumcrazycuda] #1877804
07/25/15 12:41 PM
07/25/15 12:41 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I thought about that also at one point and just went with a 727..you have to change the driveshaft..
Re: Should I rebuild my 904 or look for a 727? [Re: plumcrazycuda] #1877814
07/25/15 12:57 PM
07/25/15 12:57 PM
My 904 is gone bad! Should I rebuild it
rebuild it with premium components (within reason). lighter weight less rotating weight. they've lasted in draggers in the 10's & I'm assuming you ain't that far.
Re: Should I rebuild my 904 or look for a 727? [Re: RapidRobert] #1878802
07/26/15 11:41 PM
07/26/15 11:41 PM
PA
P
P
PA
ok I got a used 904 just to get me through the summer. It came with a lock up converter and it has a weight on it.Can I use that on a 70 340? The one that came out of it did not have that weight on it. Can I remove that weight or do I need to get a non lock up converter?
Re: Should I rebuild my 904 or look for a 727? [Re: plumcrazycuda] #1878832
07/27/15 12:07 AM
07/27/15 12:07 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
PM sent.
Careful, your character's showing!
Re: Should I rebuild my 904 or look for a 727? [Re: plumcrazycuda] #1878860
07/27/15 12:32 AM
07/27/15 12:32 AM
as you know the lockup converter needs to stay with the lockup 904. if the 340 is internally balanced then yes you can knock off any weights from the front flat face of the converter
Re: Should I rebuild my 904 or look for a 727? [Re: RapidRobert] #1878957
07/27/15 08:47 AM
07/27/15 08:47 AM
PA
P
P
PA
That's cool thanks! I did not know that the converter had to stay with the transmission. Now hope its a good one!
