Transgo SK TFSC?
#1875348
07/21/15 10:01 PM
07/21/15 10:01 PM
Posts: 364 US
f2502011
US
I ordered a Transgo SK TFSC. Comes with springs, manual valve, shims and mumbly peg. I looked over the install instructions and it keeps mentioning steel balls and checkballs. Is this something that is already in the trans or do I need to buy them separate?
1970 EK2 T/A 727
Re: Transgo SK TFSC?
[Re: f2502011]
#1875382
07/21/15 10:28 PM
07/21/15 10:28 PM
Posts: 4,684 Wichita
GY3
Wichita
They are already in the valvebody.
[Re: f2502011]
#1875478
07/22/15 12:26 AM
07/22/15 12:26 AM
Posts: 364 US
f2502011
US
Has anyone on here had experience with install that could provide any tips for install?
1970 EK2 T/A 727
[Re: f2502011]
#1877983
07/25/15 06:57 PM
07/25/15 06:57 PM
Posts: 364 US
f2502011
US
Anyone have install tips? What could I expect it to do for the trans?
1970 EK2 T/A 727
[Re: f2502011]
#1878229
07/26/15 01:50 AM
07/26/15 01:50 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
I know it comes with the valve that pumps the torque converter in park, which saves some delayed gear engagement. The check balls are already inside the valve body.
What exactly are you looking for it to do? It isn't going to make it shift hard like a TF2 kit. It's meant to correct some factory flaws and prolong trans life.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: f2502011]
#1878363
07/26/15 12:49 PM
07/26/15 12:49 PM
Posts: 364 US
f2502011
US
I would like to firm up the 2-3 shift. Not looking for hard shifts, just more firm.
1970 EK2 T/A 727
[Re: f2502011]
#1878380
07/26/15 01:17 PM
07/26/15 01:17 PM
herkamer
Lakewood, Colorado
That kit won't do it. It's not designed to improve shift quality. From their webpage: Corrects/Prevents/Reduces: Converter slip-shudder. Leaks out vent or lever. Front bushing and seal burnup. Drainback Complaint.
I would look at the TF1 Reprogramming kit. It's not as aggressive as the TF2. I put the TFOD-HD2 kit in my 518 since there really isn't another choice, and went with the mildest settings. It shifts very nice in a 4wd truck.
[Re: herkamer]
#1878656
07/26/15 09:12 PM
07/26/15 09:12 PM
Posts: 364 US
f2502011
US
It may not which is why I want to do as much research on it as possible first.
I was reading Tom Hand's guide on Allpar and the instructions and it says this pertaining to the SK-TF in the Tom Hand section:
Shift Kit
The "Shift kit" or "SK-TF" is a small version of a "Reprogramming Kit." The SK-TF can be used in fleet service and everyday vehicles. It eliminates the 2-3 shift overlap, firms up the 1-2 and 2-3 shifts (not severely), provides more fluid to the front clutch circuit, and gives a bypass to prevent excessively high fluid pressure during cold weather starts and higher RPM service.
In the instructions for the SK-TF from Transgo it gives directions for enlarging a hole in the separator plate to firm up the 2-3 shift, so that is why I'm wondering if it would help.
1970 EK2 T/A 727
[Re: f2502011]
#1878809
07/26/15 11:45 PM
07/26/15 11:45 PM
herkamer
Lakewood, Colorado
Here's the page from the TFSC kit explaining what it does with shifts. Take it for what it's worth. It may get what you are looking for.
[Re: f2502011]
#1879336
07/27/15 05:48 PM
07/27/15 05:48 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The SK-TF kit is also referred to the "No Yo-Yo" kit; it's mostly about dealing with converter drainback. It lacks any mods outside of the VB and, therefore, isn't as refined as the TF-1 or TF-2.
